[gdal-dev] Building GDAL on Ubuntu 22.04
Eric Knudstrup eric at knudstrup.org
Wed Jul 3 23:01:30 PDT 2024
I'm using WEBP, so the 3.4.1 release of GDAL that Ubuntu has won't work
for me.
Is there a workaround for this?
cmake ..
-- The CXX compiler identification is Clang 13.0.0
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - failed
-- Check for working CXX compiler: /usr/bin/clang++
-- Check for working CXX compiler: /usr/bin/clang++ - broken
CMake Error at
/snap/cmake/1403/share/cmake-3.30/Modules/CMakeTestCXXCompiler.cmake:73
(message):
   The C++ compiler
     "/usr/bin/clang++"
   is not able to compile a simple test program.
   It fails with the following output:
     Change Dir:
'/home/me/gdal-3.9.1/build/CMakeFiles/CMakeScratch/TryCompile-hpEoYa'
     Run Build Command(s): /snap/cmake/1403/bin/cmake -E env VERBOSE=1
/usr/bin/gmake -f Makefile cmTC_8efcd/fast
     /usr/bin/gmake  -f CMakeFiles/cmTC_8efcd.dir/build.make
     gmake[1]: Entering directory
     Building CXX object CMakeFiles/cmTC_8efcd.dir/testCXXCompiler.cxx.o
     /usr/bin/clang++    -MD -MT
CMakeFiles/cmTC_8efcd.dir/testCXXCompiler.cxx.o -MF
CMakeFiles/cmTC_8efcd.dir/testCXXCompiler.cxx.o.d -o
CMakeFiles/cmTC_8efcd.dir/testCXXCompiler.cxx.o -c
/home/me/gdal-3.9.1/build/CMakeFiles/CMakeScratch/TryCompile-hpEoYa/testCXXCompiler.cxx
     Linking CXX executable cmTC_8efcd
     /snap/cmake/1403/bin/cmake -E cmake_link_script
CMakeFiles/cmTC_8efcd.dir/link.txt --verbose=1
     /usr/bin/clang++ CMakeFiles/cmTC_8efcd.dir/testCXXCompiler.cxx.o -o
cmTC_8efcd
     /usr/bin/ld: cannot find -lstdc++: No such file or directory
     clang-13: error: linker command failed with exit code 1 (use -v to
see invocation)
     gmake[1]: *** [CMakeFiles/cmTC_8efcd.dir/build.make:100:
cmTC_8efcd] Error 1
     gmake[1]: Leaving directory
     gmake: *** [Makefile:127: cmTC_8efcd/fast] Error 2
   CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
   CMakeLists.txt:4 (project)
