[gdal-dev] Building GDAL on Ubuntu 22.04
Even Rouault even.rouault at spatialys.com
Sat Jul 6 00:59:24 PDT 2024
when using CLang, GDAL forces the use of libstdc++ for linking, so
seeing "cannot find -lstdc++", I suspect you might lack the installation
of libstdc++-11-dev package
Even
Le 04/07/2024 à 08:01, Eric Knudstrup via gdal-dev a écrit :
> I'm using WEBP, so the 3.4.1 release of GDAL that Ubuntu has won't
> work for me.
> Is there a workaround for this?
> cmake ..
> -- The CXX compiler identification is Clang 13.0.0
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - failed
> -- Check for working CXX compiler: /usr/bin/clang++
> -- Check for working CXX compiler: /usr/bin/clang++ - broken
> CMake Error at
> /snap/cmake/1403/share/cmake-3.30/Modules/CMakeTestCXXCompiler.cmake:73
> (message):
>   The C++ compiler
>     "/usr/bin/clang++"
>   is not able to compile a simple test program.
>   It fails with the following output:
>     Change Dir:
> '/home/me/gdal-3.9.1/build/CMakeFiles/CMakeScratch/TryCompile-hpEoYa'
>     Run Build Command(s): /snap/cmake/1403/bin/cmake -E env VERBOSE=1
> /usr/bin/gmake -f Makefile cmTC_8efcd/fast
>     /usr/bin/gmake  -f CMakeFiles/cmTC_8efcd.dir/build.make
>     gmake[1]: Entering directory
>     Building CXX object CMakeFiles/cmTC_8efcd.dir/testCXXCompiler.cxx.o
>     /usr/bin/clang++    -MD -MT
> CMakeFiles/cmTC_8efcd.dir/testCXXCompiler.cxx.o -MF
> CMakeFiles/cmTC_8efcd.dir/testCXXCompiler.cxx.o.d -o
> CMakeFiles/cmTC_8efcd.dir/testCXXCompiler.cxx.o -c
> /home/me/gdal-3.9.1/build/CMakeFiles/CMakeScratch/TryCompile-hpEoYa/testCXXCompiler.cxx
>     Linking CXX executable cmTC_8efcd
>     /snap/cmake/1403/bin/cmake -E cmake_link_script
> CMakeFiles/cmTC_8efcd.dir/link.txt --verbose=1
>     /usr/bin/clang++ CMakeFiles/cmTC_8efcd.dir/testCXXCompiler.cxx.o
> -o cmTC_8efcd
>     /usr/bin/ld: cannot find -lstdc++: No such file or directory
>     clang-13: error: linker command failed with exit code 1 (use -v to
> see invocation)
>     gmake[1]: *** [CMakeFiles/cmTC_8efcd.dir/build.make:100:
> cmTC_8efcd] Error 1
>     gmake[1]: Leaving directory
>     gmake: *** [Makefile:127: cmTC_8efcd/fast] Error 2
>   CMake will not be able to correctly generate this project.
> Call Stack (most recent call first):
>   CMakeLists.txt:4 (project)
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
