[gdal-dev] WMTS cache
Even Rouault
even.rouault at spatialys.com
Wed Jul 10 05:02:09 PDT 2024
yes, you can set the GDAL_DEFAULT_WMS_CACHE_PATH configuration option.
It is already mentioned at https://gdal.org/drivers/raster/wmts.html,
although not that much visible.
I've submitted https://github.com/OSGeo/gdal/pull/10398 to improve that.
In the meantime, you can refer to
https://gdal.org/drivers/raster/wms.html#configuration-options since the
WMS driver is unused underneath of the WMTS one.
Even
Le 10/07/2024 à 13:36, Michał Kowalczuk via gdal-dev a écrit :
> Hi,
> Is there another way to specify *gdalwmscache *folder beside using
> local service description XML file? I use direct url
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240710/2bcabf80/attachment.htm>
