[gdal-dev] WMTS cache
Michał Kowalczuk michkowalczuk at gmail.com
Wed Jul 10 06:23:51 PDT 2024
I didn’t check the WMS documentation page. There this option is more
visible.
Thank you for the solution 👍
Regards
Michał
W dniu śr., 10.07.2024 o 14:02 Even Rouault <even.rouault at spatialys.com>
napisał(a):
> yes, you can set the GDAL_DEFAULT_WMS_CACHE_PATH configuration option. It
> is already mentioned at https://gdal.org/drivers/raster/wmts.html,
> although not that much visible.
> I've submitted https://github.com/OSGeo/gdal/pull/10398 to improve that.
> In the meantime, you can refer to
> https://gdal.org/drivers/raster/wms.html#configuration-options since the
> WMS driver is unused underneath of the WMTS one.
> Even
> Le 10/07/2024 à 13:36, Michał Kowalczuk via gdal-dev a écrit :
> Hi,
> Is there another way to specify *gdalwmscache *folder beside using local
> service description XML file? I use direct url
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240710/303a5a50/attachment.htm>
