[gdal-dev] gdal docker with numpy2-compatible python bindings
Even Rouault
even.rouault at spatialys.com
Fri Jul 12 07:26:14 PDT 2024
> I hoped that the python bindings in the docker image would be
> compatible with both numpy 1 and 2, but apparently they're not? Would
> it be possible to create docker images with bindings that are
> compatible with numpy2? Or would you rather wait until the official
> ubuntu numpy package moves to 2.0?
That seems reasonable at first sight (although I'm not totally sure what
would happen if you would install and use in the same process other
python modules built against numpy 1.x. I assume this works?). If you
want to contribute that improvement, I guess this is mostly a matter of
pip install numpy==2.0.0 in the builder image before building GDAL
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240712/f357e195/attachment.htm>
