[gdal-dev] gdal docker with numpy2-compatible python bindings
Vincent Schut schut at satelligence.com
Fri Jul 12 07:29:10 PDT 2024
On 12/07/2024 16:26, Even Rouault wrote:
> Hi,
>> I hoped that the python bindings in the docker image would be
>> compatible with both numpy 1 and 2, but apparently they're not? Would
>> it be possible to create docker images with bindings that are
>> compatible with numpy2? Or would you rather wait until the official
>> ubuntu numpy package moves to 2.0?
> That seems reasonable at first sight (although I'm not totally sure
> what would happen if you would install and use in the same process
> other python modules built against numpy 1.x. I assume this works?).
> If you want to contribute that improvement, I guess this is mostly a
> matter of pip install numpy==2.0.0 in the builder image before
> building GDAL
Alright, fair enough. I'm on holidays for the next 3 1/2 weeks, but if
nobody picked it up before that, I might pick it up.
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
Vincent Schut
Remote Sensing Software Engineer
+31 302272679 ~ Maliebaan 22 | 3581CP | Utrecht | Netherlands
Linkedin <https://www.linkedin.com/company/satelligence/>~
satelligence.com <http://www.satelligence.com><http://www.satelligence.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240712/a4ca9c52/attachment-0001.htm>
