[gdal-dev] Problems compiling the project
Abel Pau a.pau at creaf.cat
Wed Jul 17 08:59:31 PDT 2024
I'm trying to compile the project using the two lines that always have worked:
cmake -B build -S . -DCMAKE_TOOLCHAIN_FILE=C:/dev/vcpkg/vcpkg/scripts/buildsystems/vcpkg.cmake -DCMAKE_BUILD_TYPE=Debug
cmake --build build
Before starting I deleted the build folder.
The first line is ok and creates the projects... but the second one gives me some red errors.
I'm using windows and Visual Studio 2019
Is there something I'm missing?
Thanks!
Generating Code...
  shapelib.vcxproj -> D:\GitHub-repository\gdal\build\ogr\ogrsf_frmts\shape\shapelib.dir\Debug\shapelib.lib
  Building Custom Rule D:/GitHub-repository/gdal/CMakeLists.txt
poppler.lib(Error.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2
' in cpl_alibaba_oss.obj [D:\GitHub-repository\gdal\build\GDAL.vcxproj]
poppler.lib(Error.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match
value 'MDd_DynamicDebug' in cpl_alibaba_oss.obj [D:\GitHub-repository\gdal\build\GDAL.vcxproj]
poppler.lib(Object.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '
2' in cpl_alibaba_oss.obj [D:\GitHub-repository\gdal\build\GDAL.vcxproj]
poppler.lib(Object.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't matc
h value 'MDd_DynamicDebug' in cpl_alibaba_oss.obj [D:\GitHub-repository\gdal\build\GDAL.vcxproj]
poppler.lib(Catalog.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value
'2' in cpl_alibaba_oss.obj [D:\GitHub-repository\gdal\build\GDAL.vcxproj]
poppler.lib(Catalog.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't mat
ch value 'MDd_DynamicDebug' in cpl_alibaba_oss.obj [D:\GitHub-repository\gdal\build\GDAL.vcxproj]
poppler.lib(XRef.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2'
poppler.lib(XRef.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match
poppler.lib(OptionalContent.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't matc
h value '2' in cpl_alibaba_oss.obj [D:\GitHub-repository\gdal\build\GDAL.vcxproj]
Abel Pau Garcia
[https://www.creaf.cat/sites/default/files/logo-creaf-small.jpg]<https://www.creaf.cat/>
GIS developer
a.pau at creaf.uab.cat <mailto:a.pau at creaf.uab.cat>
[https://www.creaf.cat/sites/default/files/cap_0.png]
Let's chat on Teams! <https://teams.microsoft.com/l/chat/0/0?users=a.pau@creaf.uab.cat>
Tel. +34 934814277
[https://www.creaf.cat/sites/default/files/x_30.png]<https://twitter.com/CREAF_ecologia>[https://www.creaf.cat/sites/default/files/linkedin_30.png]<https://www.linkedin.com/company/creaf/>[https://www.creaf.cat/sites/default/files/youtube_30.png]<https://www.youtube.com/c/creafecologia>[https://www.creaf.cat/sites/default/files/instagram_30.png]<https://www.instagram.com/CREAF_ecologia/>
www.creaf.cat <http://www.creaf.cat> | http://blog.creaf.cat
CREAF. Campus UAB. Edifici C. 08193 Bellaterra (Barcelona) <https://www.openstreetmap.org/way/123379060>
Política de privacitat <https://www.creaf.cat/ca/politica-de-privacitat>
[https://www.creaf.cat/sites/default/files/corner_right_0.png]
Abans d'imprimir aquest missatge electrònic penseu en el medi ambient.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240717/50e1f798/attachment-0001.htm>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240717/50e1f798/attachment-0001.jpg>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240717/50e1f798/attachment-0006.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240717/50e1f798/attachment-0007.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240717/50e1f798/attachment-0008.png>
Type: image/png
Desc: image005.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240717/50e1f798/attachment-0009.png>
Type: image/png
Desc: image006.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240717/50e1f798/attachment-0010.png>
Type: image/png
Desc: image007.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240717/50e1f798/attachment-0011.png>
