[gdal-dev] Adding external overviews for a VRT whose source tiles already have overviews
Craig de Stigter craig.destigter at koordinates.com
Wed Jul 17 14:11:56 PDT 2024
This was my mistake. I had set `GDAL_DISABLE_READDIR_ON_OPEN=EMPTY_DIR`,
which was preventing GDAL from noticing the .vrt.ovr file I had generated.
So, the answer is that the .vrt.ovr is just a TIF file, and it can be
generated via gdal_translate and additional overviews added to it via
gdaladdo 👍
On Wed, 17 Jul 2024 at 19:59, Craig de Stigter <
craig.destigter at koordinates.com> wrote:
> Hi folks
> I have a VRT which is a mosaic of several thousand s3-stored COGs. Doing
> any kind of low-res downsampling from this VRT causes very slow performance
> and high memory usage because it causes requests to all the individual
> source tiles.
> I'd like to add external overviews to the VRT via a `.vrt.ovr` file – and
> it appears I can do this with gdaladdo.
> However, a naive call to gdaladdo seems to ignore the overviews on all the
> source files, rendering the overviews by downloading every pixel from the
> full-size sources. This is a nonstarter in this environment where the full
> set of source tiles is enormous and remote.
> So, two questions:
> 1. Is there a way to force gdaladdo to use the COG overviews from the
> source VRT's source tiles?
> 2. If not, are there any other ways to generate a `.vrt.ovr` file which
> would use the source overviews? I have tried using gdal_translate to
> produce a .tif of the right pixel size and then renaming it to `.vrt.ovr`,
> but it doesn't seem to be used by GDAL – so I guess there's more to `ovr`
> files than just TIF files with the right name!
> Regards,
> Craig
> Platform Engineer
> Koordinates
> +64 21 256 9488 <+64%2021%20256%209488> / koordinates.com / @koordinates
> <https://twitter.com/koordinates>
Regards,
Craig
Platform Engineer
Koordinates
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240718/2831a2ba/attachment.htm>
