[gdal-dev] Adding external overviews for a VRT whose source tiles already have overviews
Craig de Stigter craig.destigter at koordinates.com
Wed Jul 17 00:59:12 PDT 2024
Hi folks
I have a VRT which is a mosaic of several thousand s3-stored COGs. Doing
any kind of low-res downsampling from this VRT causes very slow performance
and high memory usage because it causes requests to all the individual
source tiles.
I'd like to add external overviews to the VRT via a `.vrt.ovr` file – and
it appears I can do this with gdaladdo.
However, a naive call to gdaladdo seems to ignore the overviews on all the
source files, rendering the overviews by downloading every pixel from the
full-size sources. This is a nonstarter in this environment where the full
set of source tiles is enormous and remote.
So, two questions:
1. Is there a way to force gdaladdo to use the COG overviews from the
source VRT's source tiles?
2. If not, are there any other ways to generate a `.vrt.ovr` file which
would use the source overviews? I have tried using gdal_translate to
produce a .tif of the right pixel size and then renaming it to `.vrt.ovr`,
but it doesn't seem to be used by GDAL – so I guess there's more to `ovr`
files than just TIF files with the right name!
Regards,
Craig
Platform Engineer
Koordinates
+64 21 256 9488 <+64%2021%20256%209488> / koordinates.com / @koordinates
<https://twitter.com/koordinates>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240717/1389aeaf/attachment.htm>
