[gdal-dev] Building GDAL documentation with ReadTheDocs
Mike Taves
mwtoews at gmail.com
Wed Jul 24 18:30:38 PDT 2024
On Wed, 24 Jul 2024 at 22:34, Javier Jimenez Shaw via gdal-dev
<gdal-dev at lists.osgeo.org> wrote:
> Maybe the solution is that proj.org default be "stable" and not "9.4".
The reason why PROJ's RTD is configured this way is that "stable" is
set at one commit (currently 875a485f) for the most recent release, as
described by
https://docs.readthedocs.io/en/stable/versions.html
PROJ instead configures the default version as "9.4" for the 9.4
maintenance branch, which allows backports for documentation
updates/improvements for the most recent release, which precede the
release marked as "stable".
>From what I see, robots.txt is automatically configured for the default version:
https://docs.readthedocs.io/en/stable/reference/robots.html
Also worth looking at their SEO guide:
https://docs.readthedocs.io/en/stable/guides/technical-docs-seo-guide.html
