[gdal-dev] Changes in conda-forge packaging for GDAL 3.9.1
Michał Kowalczuk michkowalczuk at gmail.com
Thu Jul 25 02:58:38 PDT 2024
Continuing this topic...
What should I do if I want to use lightweight version od GDAL
(libgdal-corel) only with JP2 driver. Putting libgdal_-jp2openjpg.dll with
gdal.dll is not sufficient.
Thanks,
Michał
czw., 25 lip 2024 o 08:43 Michał Kowalczuk <michkowalczuk at gmail.com>
napisał(a):
> OK, I got it.
> I do not know who is the conda "maintainer" but it would be nice to give
> more descriptive summary for *gdal*, *libgdal *and *libgdal-core*
> packages, because now they are the same:
> *GDAL is a translator library for raster and vector geospatial data
> formats that is released under an X/MIT style Open Source license by the
> Open Source Geospatial Foundation.*
> Michał
> śr., 24 lip 2024 o 22:48 Even Rouault <even.rouault at spatialys.com>
> napisał(a):
>> Le 24/07/2024 à 22:19, Michał Kowalczuk a écrit :
>> > Hi,
>> > I've just updated GDAL with conda and I was surprised about number of
>> > dependencies that disappeared.
>> > It's quite a big change and should be mentioned in the Release Notes,
>> > not only here...
>> > Don't you think so?
>> The release notes are only about changes that occur at the source code
>> level. They are tens of packaging solutions, which are all independent
>> from the source delivery, and happen after the source release. Just
>> mentioned Conda as it is quite popular.
>> http://www.spatialys.com
>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240725/bd0f42d4/attachment.htm>
