[gdal-dev] Changes in conda-forge packaging for GDAL 3.9.1
Michał Kowalczuk michkowalczuk at gmail.com
Wed Jul 24 23:43:51 PDT 2024
OK, I got it.
I do not know who is the conda "maintainer" but it would be nice to give
more descriptive summary for *gdal*, *libgdal *and *libgdal-core* packages,
because now they are the same:
*GDAL is a translator library for raster and vector geospatial data formats
that is released under an X/MIT style Open Source license by the Open
Source Geospatial Foundation.*
Michał
śr., 24 lip 2024 o 22:48 Even Rouault <even.rouault at spatialys.com>
napisał(a):
> Le 24/07/2024 à 22:19, Michał Kowalczuk a écrit :
> > Hi,
> > I've just updated GDAL with conda and I was surprised about number of
> > dependencies that disappeared.
> > It's quite a big change and should be mentioned in the Release Notes,
> > not only here...
> > Don't you think so?
> The release notes are only about changes that occur at the source code
> level. They are tens of packaging solutions, which are all independent
> from the source delivery, and happen after the source release. Just
> mentioned Conda as it is quite popular.
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240725/a603dff3/attachment.htm>
