[gdal-dev] Changes in conda-forge packaging for GDAL 3.9.1
Even Rouault even.rouault at spatialys.com
Wed Jul 24 13:48:17 PDT 2024
Le 24/07/2024 à 22:19, Michał Kowalczuk a écrit :
> Hi,
> I've just updated GDAL with conda and I was surprised about number of
> dependencies that disappeared.
> It's quite a big change and should be mentioned in the Release Notes,
> not only here...
> Don't you think so?
The release notes are only about changes that occur at the source code
level. They are tens of packaging solutions, which are all independent
from the source delivery, and happen after the source release. Just
mentioned Conda as it is quite popular.
http://www.spatialys.com
