[gdal-dev] Changes in conda-forge packaging for GDAL 3.9.1
Michał Kowalczuk michkowalczuk at gmail.com
Wed Jul 24 13:19:31 PDT 2024
I've just updated GDAL with conda and I was surprised about number of
dependencies that disappeared.
It's quite a big change and should be mentioned in the Release Notes, not
only here...
Don't you think so?
Regards,
Michał
śr., 24 lip 2024 o 22:00 Even Rouault via gdal-dev <gdal-dev at lists.osgeo.org>
napisał(a):
> Hi,
> I just wanted to mention recent work done on the GDAL (and PDAL)
> packaging on conda-forge that may impact your use of the packages for
> GDAL >= 3.9.1.
> All details at
> https://quansight.com/post/introducing-lightweight-versions-of-gdal-and-pdal/
> TL;DR version:
> - new package libgdal-core with a reduced number of dependencies (and
> thus drivers)
> - libgdal is now a meta package that installs libgdal-core and
> libgdal-XXXX driver packages (where XXXX=hdf4, hdf5, netcdf, pdf, pg,
> tiledb, etc.)
> - gdal (python bindings + utilities) now depend just on libgdal-core,
> and not libgdal
> The full list of packages is at gdhttps://gdal.org/download.html#conda
> Credits to Quansight for the actual work and Hobu, Inc for funding it.
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240724/64599931/attachment.htm>
