[gdal-dev] Changes in conda-forge packaging for GDAL 3.9.1
Michael Smith
michael.smith.erdc at gmail.com
Thu Jul 25 03:12:50 PDT 2024
It would be just
mamba install -c conda-forge libgdal-core libgdal-jp2openjpeg
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Michał Kowalczuk via gdal-dev <gdal-dev at lists.osgeo.org>
Reply-To: Michał Kowalczuk <michkowalczuk at gmail.com>
Date: Thursday, July 25, 2024 at 6:00 AM
To: Even Rouault <even.rouault at spatialys.com>
Cc: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Changes in conda-forge packaging for GDAL 3.9.1
Continuing this topic...
What should I do if I want to use lightweight version od GDAL (libgdal-corel) only with JP2 driver. Putting libgdal_-jp2openjpg.dll with gdal.dll is not sufficient.
Thanks,
Michał
czw., 25 lip 2024 o 08:43 Michał Kowalczuk <michkowalczuk at gmail.com> napisał(a):
OK, I got it.
I do not know who is the conda "maintainer" but it would be nice to give more descriptive summary for gdal, libgdal and libgdal-core packages, because now they are the same:
GDAL is a translator library for raster and vector geospatial data formats that is released under an X/MIT style Open Source license by the Open Source Geospatial Foundation.
Michał
śr., 24 lip 2024 o 22:48 Even Rouault <even.rouault at spatialys.com> napisał(a):
Le 24/07/2024 à 22:19, Michał Kowalczuk a écrit :
> Hi,
> I've just updated GDAL with conda and I was surprised about number of
> dependencies that disappeared.
> It's quite a big change and should be mentioned in the Release Notes,
> not only here...
> Don't you think so?
The release notes are only about changes that occur at the source code
level. They are tens of packaging solutions, which are all independent
from the source delivery, and happen after the source release. Just
mentioned Conda as it is quite popular.
http://www.spatialys.com
_______________________________________________ gdal-dev mailing list gdal-dev at lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240725/9c2e406c/attachment-0001.htm>
