[gdal-dev] Changes in conda-forge packaging for GDAL 3.9.1
Michał Kowalczuk michkowalczuk at gmail.com
Thu Jul 25 13:44:05 PDT 2024
This is my DLL files structure:
archive.dll
blosc.dll
charset.dll
deflate.dll
freexl.dll
*gdal.dll*
geos.dll
geos_c.dll
geotiff.dll
iconv.dll
jpeg8.dll
krb5_64.dll
Lerc.dll
libbz2.dll
libcrypto-3-x64.dll
libcurl.dll
libexpat.dll
liblz4.dll
liblzma.dll
libminizip.dll
libpng16.dll
libsharpyuv.dll
libssh2.dll
libssl-3-x64.dll
libwebp.dll
libxml2.dll
openjp2.dll
pcre2-8.dll
proj_9_4.dll
snappy.dll
spatialite.dll
sqlite3.dll
tiff.dll
xerces-c_3_2.dll
zlib.dll
zstd.dll
*gdalplugins\gdal_JP2OpenJPEG.dll*
gdalplugins\drivers.ini
When I try to open jp2 file I get the following CPL error:
*'GDAL CPL Error 4: `D:\GisData\Formats\jp2\balloon.jp2' not recognized as
being in a supported file format. It could have been recognized by driver
JP2OpenJPEG, but plugin gdal_JP2OpenJPEG.dll is not available in your
installation. You may install it with 'conda install -c conda-forge
libgdal-jp2openjpeg'. The GDAL_DRIVER_PATH configuration option is not set.
(CE_Failure)'.*
I use conda to install libgdal-core and jp2 but later I moved necessary
dlls to different location. Maybe i missed something?
Regards,
Michał
czw., 25 lip 2024 o 12:12 Michael Smith <michael.smith.erdc at gmail.com>
napisał(a):
> It would be just
> mamba install -c conda-forge libgdal-core libgdal-jp2openjpeg
> Mike
> Michael Smith
> Remote Sensing/GIS Center
> US Army Corps of Engineers
> *From: *gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Michał
> Kowalczuk via gdal-dev <gdal-dev at lists.osgeo.org>
> *Reply-To: *Michał Kowalczuk <michkowalczuk at gmail.com>
> *Date: *Thursday, July 25, 2024 at 6:00 AM
> *To: *Even Rouault <even.rouault at spatialys.com>
> *Cc: *"gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
> *Subject: *Re: [gdal-dev] Changes in conda-forge packaging for GDAL 3.9.1
> Continuing this topic...
> What should I do if I want to use lightweight version od GDAL
> (libgdal-corel) only with JP2 driver. Putting libgdal_-jp2openjpg.dll with
> gdal.dll is not sufficient.
> Thanks,
> Michał
> czw., 25 lip 2024 o 08:43 Michał Kowalczuk <michkowalczuk at gmail.com>
> napisał(a):
> OK, I got it.
> I do not know who is the conda "maintainer" but it would be nice to give
> more descriptive summary for *gdal*, *libgdal *and *libgdal-core*
> packages, because now they are the same:
> *GDAL is a translator library for raster and vector geospatial data
> formats that is released under an X/MIT style Open Source license by the
> Open Source Geospatial Foundation.*
> Michał
> śr., 24 lip 2024 o 22:48 Even Rouault <even.rouault at spatialys.com>
> napisał(a):
> Le 24/07/2024 à 22:19, Michał Kowalczuk a écrit :
> > Hi,
> > I've just updated GDAL with conda and I was surprised about number of
> > dependencies that disappeared.
> > It's quite a big change and should be mentioned in the Release Notes,
> > not only here...
> > Don't you think so?
> The release notes are only about changes that occur at the source code
> level. They are tens of packaging solutions, which are all independent
> from the source delivery, and happen after the source release. Just
> mentioned Conda as it is quite popular.
> http://www.spatialys.com
> My software is free, but my time generally not.
> _______________________________________________ gdal-dev mailing list
> gdal-dev at lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240725/6fe008a8/attachment.htm>
