[gdal-dev] Bad gdalwarp interpolation
Calogero Mauceri mauceri at actgate.com
Fri Jul 26 00:49:00 PDT 2024
I'm rendering a 256x256 tile from a mercury dem. I noticed the gdalwarp is
producing a bad output when using interpolation with the following command
gdalwarp -of PNG -r bilinear -t_srs '+proj=eqc +a=2439700 +b=2439700
+lon_0=0.000000 +lat_0=0.000000 +x_0=0 +y_0=0 +units=m +no_defs' -ts 256
256 -te -958067.949620 -958067.950079 0.000460 0.000000 -overwrite
The output image is kind of blurred/low resolution
[image: tile.png]
On the other side, it looks good if nearest interpolation is used
gdalwarp -of PNG -t_srs '+proj=eqc +a=2439700 +b=2439700 +lon_0=0.000000
+lat_0=0.000000 +x_0=0 +y_0=0 +units=m +no_defs' -ts 256 256 -te
[image: tile.png]
The problem seems related to the fact that the right edge of the tile is
around longitude 0, while the source image is a full globe/360 degrees
image centered at 180 longitude
If I reduce the tile size to 255x255 for avoiding the 0 longitude at the
edge, then the interpolated output file looks much better
+lon_0=0.000000 +lat_0=0.000000 +x_0=0 +y_0=0 +units=m +no_defs' -ts 255
255 -te -958067.949620 -950583.044220 -7484.905400 0.000000 -overwrite
[image: tile_255.png]
Am I doing something wrong or is this a bug in GDAL?
I'm using the mercury dem from here
https://pdsimage2.wr.usgs.gov/Messenger/MESSDEM_1001/DEM/GLOBAL/IMG/
Here is a lower resolution of the same dem for testing purpose
https://
<https://pdsimage2.wr.usgs.gov/Messenger/MESSDEM_1001/DEM/GLOBAL/IMG/>
files.actgate.com/terrain/mercury/msgr_dem_low_res.tif
Thanks in advance for your help,
Calogero Mauceri
Calogero Mauceri
Software Engineer
Applied Coherent Technology Corporation (ACT)
www.actgate.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240726/4317c904/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240726/4317c904/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240726/4317c904/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240726/4317c904/attachment-0005.png>
