[gdal-dev] Bad gdalwarp interpolation
Calogero Mauceri mauceri at actgate.com
Fri Jul 26 06:19:32 PDT 2024
I just submitted a bugreport for this issue
https://github.com/OSGeo/gdal/issues/10512
On Fri, Jul 26, 2024 at 12:42 PM Calogero Mauceri <mauceri at actgate.com>
wrote:
> Thanks Javier for your reply.
> I'd like to avoid changing the source file work around.
> We are using gdalwarp C++ API as part of a general application that can
> open any kind of file.
> On Fri, Jul 26, 2024 at 12:26 PM Javier Jimenez Shaw <j1 at jimenezshaw.com>
> wrote:
>> Hi
>> I do not know if there is anything wrong in GDAL. It looks like
>> As a workaround, you can first convert the projection to be centred at
>> lon=0 with something like this (I kept the same radius as the original to
>> minimize distortion). You can add bilinear interpolation or not, as you
>> wish.
>> gdalwarp -t_srs '+proj=eqc +a=2439400 +b=2439400 +lon_0=0.000000
>> +lat_0=0.000000 +x_0=0 +y_0=0 +units=m +no_defs'-overwrite
>> msgr_dem_low_res.tif centred.tif
>> And then cut with your command.
>> I know it is not optimal because it is converting the full image. But the
>> output is not blur.
>> Cheers,
>> Javier.
>> On Fri, 26 Jul 2024 at 09:49, Calogero Mauceri via gdal-dev <
>> gdal-dev at lists.osgeo.org> wrote:
>>> Hi,
>>> I'm rendering a 256x256 tile from a mercury dem. I noticed the gdalwarp
>>> is producing a bad output when using interpolation with the following
>>> command
>>> gdalwarp -of PNG -r bilinear -t_srs '+proj=eqc +a=2439700 +b=2439700
>>> +lon_0=0.000000 +lat_0=0.000000 +x_0=0 +y_0=0 +units=m +no_defs' -ts 256
>>> 256 -te -958067.949620 -958067.950079 0.000460 0.000000 -overwrite
>>> The output image is kind of blurred/low resolution
>>> [image: tile.png]
>>> On the other side, it looks good if nearest interpolation is used
>>> gdalwarp -of PNG -t_srs '+proj=eqc +a=2439700 +b=2439700 +lon_0=0.000000
>>> +lat_0=0.000000 +x_0=0 +y_0=0 +units=m +no_defs' -ts 256 256 -te
>>> [image: tile.png]
>>> The problem seems related to the fact that the right edge of the tile is
>>> around longitude 0, while the source image is a full globe/360 degrees
>>> image centered at 180 longitude
>>> If I reduce the tile size to 255x255 for avoiding the 0 longitude at the
>>> edge, then the interpolated output file looks much better
>>> +lon_0=0.000000 +lat_0=0.000000 +x_0=0 +y_0=0 +units=m +no_defs' -ts 255
>>> 255 -te -958067.949620 -950583.044220 -7484.905400 0.000000 -overwrite
>>> [image: tile_255.png]
>>> Am I doing something wrong or is this a bug in GDAL?
>>> I'm using the mercury dem from here
>>> https://pdsimage2.wr.usgs.gov/Messenger/MESSDEM_1001/DEM/GLOBAL/IMG/
>>> Here is a lower resolution of the same dem for testing purpose
>>> https://
>>> <https://pdsimage2.wr.usgs.gov/Messenger/MESSDEM_1001/DEM/GLOBAL/IMG/>
>>> files.actgate.com/terrain/mercury/msgr_dem_low_res.tif
>>> Thanks in advance for your help,
>>> Calogero Mauceri
>>> Calogero Mauceri
>>> Software Engineer
>>> Applied Coherent Technology Corporation (ACT)
>>> www.actgate.com
>>> gdal-dev mailing list
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Calogero Mauceri
> Software Engineer
> www.actgate.com
Calogero Mauceri
Software Engineer
www.actgate.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240726/c16bf58f/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240726/c16bf58f/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240726/c16bf58f/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240726/c16bf58f/attachment-0005.png>
