[gdal-dev] cmake error: IMPORTED_LOCATION not set for imported target "GEOTIFF::GEOTIFF"
Even Rouault
even.rouault at spatialys.com
Tue Jun 4 08:29:00 PDT 2024
I don't reproduce this on my Linux setup. Can you give more information on:
- your operating system
- CMake version
- cmake command line you used to build libgeotiff
- cmake command line you use to build GDAL
Also, if you've reused an existing GDAL build directory that was used
with a prior libgeotiff version, perhaps try rebuilding in a fresh build
directory. libgeotiff CMake
Even
Le 04/06/2024 à 16:29, Hernán De Angelis via gdal-dev a écrit :
> Hello!
> While building GDAL 3.9.0 with libtiff 1.7.3 I am getting this error
> from ccmake when generating:
> CMake Error in CMakeLists.txt:
> configuration "Release".
> I am used to build GDAL from source but never seen this before. Any
> hint on what does this mean and how to get around?
> Thanks in advance!
> Hernán
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
