[gdal-dev] cmake error: IMPORTED_LOCATION not set for imported target "GEOTIFF::GEOTIFF"
Hernán De Angelis
variablestarlight at gmail.com
Tue Jun 4 10:04:26 PDT 2024
Thank you Even! That was it. Started with a fresh GDAL 3.9.0 directory
and everything went fine as usual.
Best!
Hernán
Den 2024-06-04 kl. 17:29, skrev Even Rouault:
> if you've reused an existing GDAL build directory that was used with a
> prior libgeotiff version, perhaps try rebuilding in a fresh build
> directory. libgeotiff CMake
