[gdal-dev] doc bugs about prereqs, surfaced by updating pkgsrc for 3.9
Greg Troxel
gdt at lexort.com
Thu Jun 6 11:13:29 PDT 2024
Even Rouault <even.rouault at spatialys.com> writes:
>> which is misplaced, because people are who merely intending to compile
>> gdal but not contribute to it, still need to know. I almost didn't even
>> look at it before writing that it wasn't documented which C++ flavor is
>> needed, because it was obviously not about what I needed to know.
> Attempt to improve in https://github.com/OSGeo/gdal/pull/10151
great, have commented.
>> 2) NEWS for 3.9 does not mention that there is now a requirement for a C++17
>> compiler.
> ==> 3rd bullet point of "In a nutshell"
> * [RFC
> 98](https://gdal.org/development/rfc/rfc98_build_requirements_gdal_3_9.html):
> Build requirements for GDAL 3.9
I see. I didn't find that searching for C++17.... For packagers
reading, I would like to see
* a C++17 compiler is now required
not a link to some RFC, basically inlining what's new. Increased build
requirements are a huge big deal, because they need to be encoded in
packaging control files. Especially compilers, because on many systems,
updating compilers is harder than updating geos along with gdal.
>> 3) The person also marked gdal for c17
> Can you be more explicit about you mean by "the person also marked
> gdal for c17" : where exactly?
In pkgsrc, we have checked in control files that decribe how to build
each package. The gdal-lib package recently had a change to that file
saying that the C compiler must support C17, and I am suspecting that
requiring C17 is incorrect. It's not in RFC98 either. And you didn't
say "oh yeah we need c17 now".
gcc7, in NetBSD 9, supports almost all of c++17, but it seems that 100%
support is not until gcc8. We may have an incorrect mapping c++17->7
when it should be 8.
Specifically:
Template argument deduction for class templates
P0512R0
needs 8.
So the big question is if gdal builds with gcc7, or if it needs 8.
