[gdal-dev] gdal2xyz
Even Rouault
even.rouault at spatialys.com
Tue Jun 11 12:31:06 PDT 2024
Le 11/06/2024 à 21:22, Andrew Bell via gdal-dev a écrit :
> Hi,
> The documentation describes an application `gdal2xyz`, but I don't see
> one built in my development environment. I also don't see anything in
> the CMakeLists.txt that refers to it. Is it named something I'm not
> expecting? Does it still exist?
Yes, it still exists. This is a Python utility. In your build
environment, if you source scripts/setdevenv.sh, your path will include
$build_dir/swig/python/gdal-utils/scripts where you can find it. There,
it will be available only with the .py extension. It is also available
without the .py extension through a launcher script if you install the
gdal or gdal-utils packages (with make install).
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240611/f270fa10/attachment.htm>
