[gdal-dev] gdal2xyz
Even Rouault
even.rouault at spatialys.com
Tue Jun 11 16:17:11 PDT 2024
Le 11/06/2024 à 21:31, Even Rouault via gdal-dev a écrit :
> Le 11/06/2024 à 21:22, Andrew Bell via gdal-dev a écrit :
>> Hi,
>> The documentation describes an application `gdal2xyz`, but I don't
>> see one built in my development environment. I also don't see
>> anything in the CMakeLists.txt that refers to it. Is it named
>> something I'm not expecting? Does it still exist?
> Yes, it still exists. This is a Python utility. In your build
> environment, if you source scripts/setdevenv.sh, your path will
> include $build_dir/swig/python/gdal-utils/scripts where you can find
> it. There, it will be available only with the .py extension. It is
> also available without the .py extension through a launcher script if
> you install the gdal or gdal-utils packages (with make install).
==> https://github.com/OSGeo/gdal/pull/10195 to also add launcher
scripts without .py extension for development environment
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240612/7f3d2b56/attachment.htm>
