[gdal-dev] GDAL 3.9.1 RC2 is available, and motion to approve it
Even Rouault
even.rouault at spatialys.com
Sat Jun 22 15:13:00 PDT 2024
I've issued a 2nd release candidate for 3.9.1 with the following
additional fixes:
- GDALSieveFilter(): avoid assert() when all pixels are masked (3.9.0
regression)
(raster/rasterio#3101)
- Overview generation: fix multi-threaded bug, resulting in
locks/crashes with
GeoPackage in particular (#10245)
- VRT: fix serialization of separatable kernel in
VRTKernelFilteredSource (#10253)
- Zarr: SerializeNumericNoData(): use CPLJSonObject::Add(uint64_t) to
avoid potential
undefined behavior casts
- OGR SQL: fix crash when the ON expression of a JOIN contains OGR special
fields (in particular feature id)
- OGR layer algebra: honour PROMOTE_TO_MULTI=YES for Points
- OGRFeature::SetField(int, double): avoid UndefinedBehavior when
passing NaN
- OGRFeature::SetField(int, GIntBig): avoid UndefinedBehavior when
passing value
close to INT64_MAX
- OGRLayer::WriteArrowBatch(): avoid UndefinedBehavior when trying to
convert
NaN to Int64
- GeoParquet: always write version=1.1.0
- SQLite/GPKG: detect UNIQUE constraints expressed as a ', CONSTRAINT
name UNIQUE (column_name)'
at the end of CREATE TABLE (qgis/QGIS#57823)
- GDALRasterBand::ComputeStatistics(): fix bad progress percentage
computation (3.9.1rc1 regression)
- OGRSpatialReference::importFromUSGS(): avoid out-of-bounds access to
array (3.9.1rc1 regression)
Pick up an archive among the following ones (by ascending size):
https://download.osgeo.org/gdal/3.9.1/gdal-3.9.1rc2.tar.xz
https://download.osgeo.org/gdal/3.9.1/gdal-3.9.1rc2.tar.gz
https://download.osgeo.org/gdal/3.9.1/gdal391rc2.zip
A snapshot of the gdalautotest suite is also available:
https://download.osgeo.org/gdal/3.9.1/gdalautotest-3.9.1rc2.tar.gz
https://download.osgeo.org/gdal/3.9.1/gdalautotest-3.9.1rc2.zip
The NEWS file is here:
https://github.com/OSGeo/gdal/blob/v3.9.1RC2/NEWS.md
Even
http://www.spatialys.com
