[gdal-dev] GDAL 3.9.1 RC2 is available, and motion to approve it
Even Rouault even.rouault at spatialys.com
Mon Jun 24 07:06:51 PDT 2024
Forgot to add my +1 obviously
Le 23/06/2024 à 00:13, Even Rouault via gdal-dev a écrit :
> I've issued a 2nd release candidate for 3.9.1 with the following
> additional fixes:
> - GDALSieveFilter(): avoid assert() when all pixels are masked (3.9.0
> regression)
>   (raster/rasterio#3101)
> - Overview generation: fix multi-threaded bug, resulting in
> locks/crashes with
>   GeoPackage in particular (#10245)
> - VRT: fix serialization of separatable kernel in
> VRTKernelFilteredSource (#10253)
> - Zarr: SerializeNumericNoData(): use CPLJSonObject::Add(uint64_t) to
> avoid potential
>   undefined behavior casts
> - OGR SQL: fix crash when the ON expression of a JOIN contains OGR
> special
>   fields (in particular feature id)
> - OGR layer algebra: honour PROMOTE_TO_MULTI=YES for Points
> - OGRFeature::SetField(int, double): avoid UndefinedBehavior when
> passing NaN
> - OGRFeature::SetField(int, GIntBig): avoid UndefinedBehavior when
> passing value
>   close to INT64_MAX
> - OGRLayer::WriteArrowBatch(): avoid UndefinedBehavior when trying to
> convert
>   NaN to Int64
> - GeoParquet: always write version=1.1.0
> - SQLite/GPKG: detect UNIQUE constraints expressed as a ', CONSTRAINT
> name UNIQUE (column_name)'
>   at the end of CREATE TABLE (qgis/QGIS#57823)
> - GDALRasterBand::ComputeStatistics(): fix bad progress percentage
> computation (3.9.1rc1 regression)
> - OGRSpatialReference::importFromUSGS(): avoid out-of-bounds access to
> array (3.9.1rc1 regression)
> Pick up an archive among the following ones (by ascending size):
>   https://download.osgeo.org/gdal/3.9.1/gdal-3.9.1rc2.tar.xz
>   https://download.osgeo.org/gdal/3.9.1/gdal-3.9.1rc2.tar.gz
>   https://download.osgeo.org/gdal/3.9.1/gdal391rc2.zip
> A snapshot of the gdalautotest suite is also available:
> https://download.osgeo.org/gdal/3.9.1/gdalautotest-3.9.1rc2.tar.gz
>   https://download.osgeo.org/gdal/3.9.1/gdalautotest-3.9.1rc2.zip
> The NEWS file is here:
>    https://github.com/OSGeo/gdal/blob/v3.9.1RC2/NEWS.md
> Even
http://www.spatialys.com
