[gdal-dev] GDAL 3.9.1 RC2 is available, and motion to approve it
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Mon Jun 24 07:35:04 PDT 2024
+1
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Even Rouault via gdal-dev
Lähetetty: maanantai 24. kesäkuuta 2024 17.07
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: Re: [gdal-dev] GDAL 3.9.1 RC2 is available, and motion to approve it
Forgot to add my +1 obviously
Le 23/06/2024 à 00:13, Even Rouault via gdal-dev a écrit :
> I've issued a 2nd release candidate for 3.9.1 with the following
> additional fixes:
> - GDALSieveFilter(): avoid assert() when all pixels are masked (3.9.0
> regression)
> (raster/rasterio#3101)
> - Overview generation: fix multi-threaded bug, resulting in
> locks/crashes with
> GeoPackage in particular (#10245)
> - VRT: fix serialization of separatable kernel in
> VRTKernelFilteredSource (#10253)
> - Zarr: SerializeNumericNoData(): use CPLJSonObject::Add(uint64_t) to
> avoid potential
> undefined behavior casts
> - OGR SQL: fix crash when the ON expression of a JOIN contains OGR
> special
> fields (in particular feature id)
> - OGR layer algebra: honour PROMOTE_TO_MULTI=YES for Points
> - OGRFeature::SetField(int, double): avoid UndefinedBehavior when
> passing NaN
> - OGRFeature::SetField(int, GIntBig): avoid UndefinedBehavior when
> passing value
> close to INT64_MAX
> - OGRLayer::WriteArrowBatch(): avoid UndefinedBehavior when trying to
> convert
> NaN to Int64
> - GeoParquet: always write version=1.1.0
> - SQLite/GPKG: detect UNIQUE constraints expressed as a ', CONSTRAINT
> name UNIQUE (column_name)'
> at the end of CREATE TABLE (qgis/QGIS#57823)
> - GDALRasterBand::ComputeStatistics(): fix bad progress percentage
> computation (3.9.1rc1 regression)
> - OGRSpatialReference::importFromUSGS(): avoid out-of-bounds access to
> array (3.9.1rc1 regression)
> Pick up an archive among the following ones (by ascending size):
> https://down/
> load.osgeo.org%2Fgdal%2F3.9.1%2Fgdal-3.9.1rc2.tar.xz&data=05%7C02%7Cju
> kka.rahkonen%40maanmittauslaitos.fi%7C8a878635699b4327b7a808dc9456f122
> %7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C638548353038914451%7CUnk
> nown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWw
> iLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=QKDKxmtYu3yqWkt%2BEJoWs2F%2FDP%2F2d
> NXNrJeqdpzJ2lY%3D&reserved=0
> https://down/
> load.osgeo.org%2Fgdal%2F3.9.1%2Fgdal-3.9.1rc2.tar.gz&data=05%7C02%7Cju
> %7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C638548353038923721%7CUnk
> iLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=k%2FwOHtldnSwPj27c7KqPojnTO%2FOQwMh
> CYGHZC9HuZ5w%3D&reserved=0
> https://down/
> load.osgeo.org%2Fgdal%2F3.9.1%2Fgdal391rc2.zip&data=05%7C02%7Cjukka.ra
> hkonen%40maanmittauslaitos.fi%7C8a878635699b4327b7a808dc9456f122%7Cc4f
> 8a63255804a1c92371d5a571b71fa%7C0%7C0%7C638548353038929699%7CUnknown%7
> CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXV
> CI6Mn0%3D%7C0%7C%7C%7C&sdata=206oYiEKWF2bTeYN6SsWa4fq8nBSPKWhhtPqYCzBc
> pw%3D&reserved=0
> A snapshot of the gdalautotest suite is also available:
> https://down/
> load.osgeo.org%2Fgdal%2F3.9.1%2Fgdalautotest-3.9.1rc2.tar.gz&data=05%7
> C02%7Cjukka.rahkonen%40maanmittauslaitos.fi%7C8a878635699b4327b7a808dc
> 9456f122%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C6385483530389349
> 68%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI
> 6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=MPXYE%2FWq%2BwnMYK6tKCpid9b
> eoCPWFY%2BBefivpTHpjNE%3D&reserved=0
> https://down/
> load.osgeo.org%2Fgdal%2F3.9.1%2Fgdalautotest-3.9.1rc2.zip&data=05%7C02
> %7Cjukka.rahkonen%40maanmittauslaitos.fi%7C8a878635699b4327b7a808dc945
> 6f122%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C638548353038939284%
> 7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik
> 1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=o6qmt5kC1FbwhjGdIlH3cnlQRezBKO
> KoW80sjdtvxcY%3D&reserved=0
> The NEWS file is here:
> https://gith/
> ub.com%2FOSGeo%2Fgdal%2Fblob%2Fv3.9.1RC2%2FNEWS.md&data=05%7C02%7Cjukk
> a.rahkonen%40maanmittauslaitos.fi%7C8a878635699b4327b7a808dc9456f122%7
> Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C638548353038943612%7CUnkno
> wn%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiL
> CJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=bO%2ByyJi9Pbq%2BV9i09xFtnn8hG6iJQbzmZ
> UMW%2Bfwo%2FC0%3D&reserved=0
> Even
http://www.spatialys.com/
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
