[gdal-dev] GDAL 3.9.1 RC2 is available, and motion to approve it
    Tamas Szekeres
    szekerest at gmail.com
    Mon Jun 24 07:46:49 PDT 2024
+1
Tamas
Even Rouault via gdal-dev <gdal-dev at lists.osgeo.org> ezt írta (időpont:
2024. jún. 23., V, 0:13):
> I've issued a 2nd release candidate for 3.9.1 with the following
> additional fixes:
> - GDALSieveFilter(): avoid assert() when all pixels are masked (3.9.0
> regression)
>    (raster/rasterio#3101)
> - Overview generation: fix multi-threaded bug, resulting in
> locks/crashes with
>    GeoPackage in particular (#10245)
> - VRT: fix serialization of separatable kernel in
> VRTKernelFilteredSource (#10253)
> - Zarr: SerializeNumericNoData(): use CPLJSonObject::Add(uint64_t) to
> avoid potential
>    undefined behavior casts
> - OGR SQL: fix crash when the ON expression of a JOIN contains OGR special
>    fields (in particular feature id)
> - OGR layer algebra: honour PROMOTE_TO_MULTI=YES for Points
> - OGRFeature::SetField(int, double): avoid UndefinedBehavior when
> passing NaN
> - OGRFeature::SetField(int, GIntBig): avoid UndefinedBehavior when
> passing value
>    close to INT64_MAX
> - OGRLayer::WriteArrowBatch(): avoid UndefinedBehavior when trying to
> convert
>    NaN to Int64
> - GeoParquet: always write version=1.1.0
> - SQLite/GPKG: detect UNIQUE constraints expressed as a ', CONSTRAINT
> name UNIQUE (column_name)'
>    at the end of CREATE TABLE (qgis/QGIS#57823)
> - GDALRasterBand::ComputeStatistics(): fix bad progress percentage
> computation (3.9.1rc1 regression)
> - OGRSpatialReference::importFromUSGS(): avoid out-of-bounds access to
> array (3.9.1rc1 regression)
> Pick up an archive among the following ones (by ascending size):
>    https://download.osgeo.org/gdal/3.9.1/gdal-3.9.1rc2.tar.xz
>    https://download.osgeo.org/gdal/3.9.1/gdal-3.9.1rc2.tar.gz
>    https://download.osgeo.org/gdal/3.9.1/gdal391rc2.zip
> A snapshot of the gdalautotest suite is also available:
> https://download.osgeo.org/gdal/3.9.1/gdalautotest-3.9.1rc2.tar.gz
>    https://download.osgeo.org/gdal/3.9.1/gdalautotest-3.9.1rc2.zip
> The NEWS file is here:
>     https://github.com/OSGeo/gdal/blob/v3.9.1RC2/NEWS.md
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240624/26fc4f3a/attachment.htm>
