[gdal-dev] Error linking srsinfo in 3.9.1 (rc1 or rc2)
Even Rouault
even.rouault at spatialys.com
Mon Jun 24 10:01:02 PDT 2024
What is the version of your Debian system ? Is it "clean" ? Can you for
example reproduce in the corresponding debian:XXX docker image?
https://www.google.com/search?q=fatal+error%3A+stdlib.h%3A+No+such+file+or+directory+"
shows that this error message is quite common, although on quick
reading, I couldn't spot a common point/solution between all those
occurrences
Even
Le 24/06/2024 à 18:39, Scott via gdal-dev a écrit :
> When building 3.9.1 rc1/r2 I get the following when linking. If I
> comment srsinfo out of the makefile, all other gdal/ogr apps build
> fine with no issues.
> uname -a:
> Linux MyHost 6.1.0-21-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.90-1
> (2024-05-03) x86_64 GNU/Linux
> Thanks!
> Build output below:
> [ 98%] Building CXX object
> apps/CMakeFiles/gdalsrsinfo.dir/gdalsrsinfo.cpp.o
> In file included from /usr/include/c++/12/ext/string_conversions.h:41,
> from /usr/include/c++/12/bits/basic_string.h:3960,
> from /usr/include/c++/12/string:53,
> from
> /export/gis/local/src/gdal-3.9.1/port/cpl_error.h:256,
> from
> /export/gis/local/src/gdal-3.9.1/port/cpl_string.h:35,
> from
> /export/gis/local/src/gdal-3.9.1/apps/gdalsrsinfo.cpp:32:
> /usr/include/c++/12/cstdlib:75:15: fatal error: stdlib.h: No such file
> or directory
> 75 | #include_next <stdlib.h>
> compilation terminated.
> make[2]: *** [apps/CMakeFiles/gdalsrsinfo.dir/build.make:76:
> apps/CMakeFiles/gdalsrsinfo.dir/gdalsrsinfo.cpp.o] Error 1
> make[1]: *** [CMakeFiles/Makefile2:10247:
> apps/CMakeFiles/gdalsrsinfo.dir/all] Error 2
> make: *** [Makefile:146: all] Error 2
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
