[gdal-dev] Error linking srsinfo in 3.9.1 (rc1 or rc2)
Scott
public at postholer.com
Mon Jun 24 10:15:42 PDT 2024
It's Debian 12. No, it's not clean. It's had several versions of gdal,
et al, on it.
It appears srsinfo in not finding stdlib.h and all the other apps do,
which is the part I found odd.
Docker is not the environment I'm building in.
Thanks!
On 6/24/24 10:01, Even Rouault wrote:
> Hi,
> What is the version of your Debian system ? Is it "clean" ? Can you for
> example reproduce in the corresponding debian:XXX docker image?
> https://www.google.com/search?q=fatal+error%3A+stdlib.h%3A+No+such+file+or+directory+" shows that this error message is quite common, although on quick reading, I couldn't spot a common point/solution between all those occurrences
> Even
> Le 24/06/2024 à 18:39, Scott via gdal-dev a écrit :
>> When building 3.9.1 rc1/r2 I get the following when linking. If I
>> comment srsinfo out of the makefile, all other gdal/ogr apps build
>> fine with no issues.
>> uname -a:
>> Linux MyHost 6.1.0-21-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.90-1
>> (2024-05-03) x86_64 GNU/Linux
>> Thanks!
>> Build output below:
>> [ 98%] Building CXX object
>> apps/CMakeFiles/gdalsrsinfo.dir/gdalsrsinfo.cpp.o
>> In file included from /usr/include/c++/12/ext/string_conversions.h:41,
>> from /usr/include/c++/12/bits/basic_string.h:3960,
>> from /usr/include/c++/12/string:53,
>> from
>> /export/gis/local/src/gdal-3.9.1/port/cpl_error.h:256,
>> from
>> /export/gis/local/src/gdal-3.9.1/port/cpl_string.h:35,
>> from
>> /export/gis/local/src/gdal-3.9.1/apps/gdalsrsinfo.cpp:32:
>> /usr/include/c++/12/cstdlib:75:15: fatal error: stdlib.h: No such file
>> or directory
>> 75 | #include_next <stdlib.h>
>> compilation terminated.
>> make[2]: *** [apps/CMakeFiles/gdalsrsinfo.dir/build.make:76:
>> apps/CMakeFiles/gdalsrsinfo.dir/gdalsrsinfo.cpp.o] Error 1
>> make[1]: *** [CMakeFiles/Makefile2:10247:
>> apps/CMakeFiles/gdalsrsinfo.dir/all] Error 2
>> make: *** [Makefile:146: all] Error 2
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
