[gdal-dev] Error linking srsinfo in 3.9.1 (rc1 or rc2)
Scott public at postholer.com
Mon Jun 24 10:52:57 PDT 2024
Thanks for the docker instructions. It built nice and clean.
That still leaves the question, in my environment, why do all the apps
except gdalsrsinfo build? I seriously doubt stdlib.h is only used by
gdalsrsinfo.
Thanks for the help! I'll try and figure it out.
On 6/24/24 10:25, Even Rouault wrote:
> Le 24/06/2024 à 19:15, Scott a écrit :
>> It's Debian 12. No, it's not clean. It's had several versions of gdal,
>> et al, on it.
>> It appears srsinfo in not finding stdlib.h and all the other apps do,
>> which is the part I found odd.
>> Docker is not the environment I'm building in.
> yes, but that's the most convenient way for me to try to reproduce all
> the diverse environments people can use
> Just trying the following works fine for me:
> docker run --rm -it -v /home/even/gdal/3.9:/home/even/gdal/3.9 debian:12
> (inside it)
> cd /home/even/gdal/3.9/build_debian_12/
> apt update && apt install cmake g++ make libproj-dev
> cmake ..
> make -j$(nproc)
>> Thanks!
>> On 6/24/24 10:01, Even Rouault wrote:
>>> Hi,
>>> What is the version of your Debian system ? Is it "clean" ? Can you
>>> for example reproduce in the corresponding debian:XXX docker image?
>>> https://www.google.com/search?q=fatal+error%3A+stdlib.h%3A+No+such+file+or+directory+" shows that this error message is quite common, although on quick reading, I couldn't spot a common point/solution between all those occurrences
>>> Even
>>> Le 24/06/2024 à 18:39, Scott via gdal-dev a écrit :
>>>> When building 3.9.1 rc1/r2 I get the following when linking. If I
>>>> comment srsinfo out of the makefile, all other gdal/ogr apps build
>>>> fine with no issues.
>>>> uname -a:
>>>> Linux MyHost 6.1.0-21-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.90-1
>>>> (2024-05-03) x86_64 GNU/Linux
>>>> Thanks!
>>>> Build output below:
>>>> [ 98%] Building CXX object
>>>> apps/CMakeFiles/gdalsrsinfo.dir/gdalsrsinfo.cpp.o
>>>> In file included from /usr/include/c++/12/ext/string_conversions.h:41,
>>>>                  from /usr/include/c++/12/bits/basic_string.h:3960,
>>>>                  from /usr/include/c++/12/string:53,
>>>>                  from
>>>> /export/gis/local/src/gdal-3.9.1/port/cpl_error.h:256,
>>>>                  from
>>>> /export/gis/local/src/gdal-3.9.1/port/cpl_string.h:35,
>>>>                  from
>>>> /export/gis/local/src/gdal-3.9.1/apps/gdalsrsinfo.cpp:32:
>>>> /usr/include/c++/12/cstdlib:75:15: fatal error: stdlib.h: No such
>>>> file or directory
>>>>    75 | #include_next <stdlib.h>
>>>> compilation terminated.
>>>> make[2]: *** [apps/CMakeFiles/gdalsrsinfo.dir/build.make:76:
>>>> apps/CMakeFiles/gdalsrsinfo.dir/gdalsrsinfo.cpp.o] Error 1
>>>> make[1]: *** [CMakeFiles/Makefile2:10247:
>>>> apps/CMakeFiles/gdalsrsinfo.dir/all] Error 2
>>>> make: *** [Makefile:146: all] Error 2
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
