[gdal-dev] Error linking srsinfo in 3.9.1 (rc1 or rc2)
Barry DeZonia
bdezonia at gmail.com
Mon Jun 24 10:57:27 PDT 2024
Scott, is it that you are using #include_next instead of #include?
#include_next makes assumptions about the environment that #include does
not.
On Mon, Jun 24, 2024 at 12:53 PM Scott via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Thanks for the docker instructions. It built nice and clean.
> That still leaves the question, in my environment, why do all the apps
> except gdalsrsinfo build? I seriously doubt stdlib.h is only used by
> gdalsrsinfo.
> Thanks for the help! I'll try and figure it out.
> On 6/24/24 10:25, Even Rouault wrote:
> > Le 24/06/2024 à 19:15, Scott a écrit :
> >> It's Debian 12. No, it's not clean. It's had several versions of gdal,
> >> et al, on it.
> >> It appears srsinfo in not finding stdlib.h and all the other apps do,
> >> which is the part I found odd.
> >> Docker is not the environment I'm building in.
> > yes, but that's the most convenient way for me to try to reproduce all
> > the diverse environments people can use
> > Just trying the following works fine for me:
> > docker run --rm -it -v /home/even/gdal/3.9:/home/even/gdal/3.9 debian:12
> > (inside it)
> > cd /home/even/gdal/3.9/build_debian_12/
> > apt update && apt install cmake g++ make libproj-dev
> > cmake ..
> > make -j$(nproc)
> >> Thanks!
> >> On 6/24/24 10:01, Even Rouault wrote:
> >>> Hi,
> >>> What is the version of your Debian system ? Is it "clean" ? Can you
> >>> for example reproduce in the corresponding debian:XXX docker image?
> https://www.google.com/search?q=fatal+error%3A+stdlib.h%3A+No+such+file+or+directory+"
> shows that this error message is quite common, although on quick reading, I
> couldn't spot a common point/solution between all those occurrences
> >>> Even
> >>> Le 24/06/2024 à 18:39, Scott via gdal-dev a écrit :
> >>>> When building 3.9.1 rc1/r2 I get the following when linking. If I
> >>>> comment srsinfo out of the makefile, all other gdal/ogr apps build
> >>>> fine with no issues.
> >>>> uname -a:
> >>>> Linux MyHost 6.1.0-21-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.90-1
> >>>> (2024-05-03) x86_64 GNU/Linux
> >>>> Thanks!
> >>>> Build output below:
> >>>> [ 98%] Building CXX object
> >>>> apps/CMakeFiles/gdalsrsinfo.dir/gdalsrsinfo.cpp.o
> >>>> In file included from /usr/include/c++/12/ext/string_conversions.h:41,
> >>>> from /usr/include/c++/12/bits/basic_string.h:3960,
> >>>> from /usr/include/c++/12/string:53,
> >>>> from
> >>>> /export/gis/local/src/gdal-3.9.1/port/cpl_error.h:256,
> >>>> from
> >>>> /export/gis/local/src/gdal-3.9.1/port/cpl_string.h:35,
> >>>> from
> >>>> /export/gis/local/src/gdal-3.9.1/apps/gdalsrsinfo.cpp:32:
> >>>> /usr/include/c++/12/cstdlib:75:15: fatal error: stdlib.h: No such
> >>>> file or directory
> >>>> 75 | #include_next <stdlib.h>
> >>>> compilation terminated.
> >>>> make[2]: *** [apps/CMakeFiles/gdalsrsinfo.dir/build.make:76:
> >>>> apps/CMakeFiles/gdalsrsinfo.dir/gdalsrsinfo.cpp.o] Error 1
> >>>> make[1]: *** [CMakeFiles/Makefile2:10247:
> >>>> apps/CMakeFiles/gdalsrsinfo.dir/all] Error 2
> >>>> make: *** [Makefile:146: all] Error 2
> >>>> _______________________________________________
> >>>> gdal-dev mailing list
> >>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240624/fccbde48/attachment.htm>
