[gdal-dev] testclosedondestroydm.test
Andrew C Aitchison
andrew at aitchison.me.uk
Tue Jun 25 06:14:45 PDT 2024
This is not a new failure, so thre is no need for this to hold up 3.9.1.
System: Ubuntu 24-04/Noble on Intel x86-64.
# ctest --output-on-failure
---- 8< ---- 8< ---- 8< ---- 8< ---- 8< ---- 8< ---- 8< ----
28/51 Test #28: test-closed-on-destroy-DM ........***Failed 0.19 sec
[==========] Running 1 test from 1 test suite.
[----------] Global test environment set-up.
[----------] 1 test from testclosedondestroydm
[ RUN ] testclosedondestroydm.test
ERROR 4: /home/werdna/gdal/3.9.1/gdal-3.9.1/autotest/gdrivers/data/dimap/rgbsmall.tif: No such file or directory
ERROR 3: Checksum value could not be computed due to I/O read error.
ERROR 4: /home/werdna/gdal/3.9.1/gdal-3.9.1/autotest/gdrivers/tmp/cache/file9_j2c.ntf: No such file or directory
Warning 1: byte3.tif: File open for read-only accessing, creating mask externally.
ERROR 4: `/home/werdna/gdal/3.9.1/gdal-3.9.1/autotest/gdrivers/data/sid/mercator.sid'
not recognized as being in a supported file format.
unknown file: Failure
C++ exception with description "basic_string::_M_create" thrown in the test body.
[ FAILED ] testclosedondestroydm.test (157 ms)
[----------] 1 test from testclosedondestroydm (157 ms total)
[----------] Global test environment tear-down
[==========] 1 test from 1 test suite ran. (157 ms total)
[ PASSED ] 0 tests.
[ FAILED ] 1 test, listed below:
1 FAILED TEST
Indeed
does not exist, but
/home/werdna/gdal/3.9.1/gdal-3.9.1/autotest/gdrivers/data/rgbsmall.tif
does.
(I cannot find a file9_j2c with any extension anywhere, but I guess it is supposed to be built at test time.)
Full ctest log at:
https://www.aitchison.me.uk/gdal/ctest.391.gnu.errlog
Andrew C. Aitchison Kendal, UK
