[gdal-dev] testclosedondestroydm.test
Even Rouault
even.rouault at spatialys.com
Tue Jun 25 06:21:54 PDT 2024
Can you run "gdb autotest/cpp/testclosedondestroydm" , "run" , and when
it crashed "bt" so we have a backtrace of where it crashes (all of that
after running "source ../scripts/setdevenv.sh")
Le 25/06/2024 à 15:14, Andrew C Aitchison via gdal-dev a écrit :
> This is not a new failure, so thre is no need for this to hold up 3.9.1.
> System: Ubuntu 24-04/Noble on Intel x86-64.
> # ctest --output-on-failure
> ---- 8< ---- 8< ---- 8< ---- 8< ---- 8< ---- 8< ---- 8< ----
> 28/51 Test #28: test-closed-on-destroy-DM ........***Failed 0.19 sec
> [==========] Running 1 test from 1 test suite.
> [----------] Global test environment set-up.
> [----------] 1 test from testclosedondestroydm
> [ RUN ] testclosedondestroydm.test
> ERROR 4:
> /home/werdna/gdal/3.9.1/gdal-3.9.1/autotest/gdrivers/data/dimap/rgbsmall.tif:
> No such file or directory
> ERROR 3: Checksum value could not be computed due to I/O read error.
> ERROR 4:
> /home/werdna/gdal/3.9.1/gdal-3.9.1/autotest/gdrivers/tmp/cache/file9_j2c.ntf:
> Warning 1: byte3.tif: File open for read-only accessing, creating mask
> externally.
> ERROR 4:
> `/home/werdna/gdal/3.9.1/gdal-3.9.1/autotest/gdrivers/data/sid/mercator.sid'
> not recognized as being in a supported file format.
> unknown file: Failure
> C++ exception with description "basic_string::_M_create" thrown in the
> test body.
> [ FAILED ] testclosedondestroydm.test (157 ms)
> [----------] 1 test from testclosedondestroydm (157 ms total)
> [----------] Global test environment tear-down
> [==========] 1 test from 1 test suite ran. (157 ms total)
> [ PASSED ] 0 tests.
> [ FAILED ] 1 test, listed below:
> 1 FAILED TEST
> Indeed
> does not exist, but
> /home/werdna/gdal/3.9.1/gdal-3.9.1/autotest/gdrivers/data/rgbsmall.tif
> does.
> (I cannot find a file9_j2c with any extension anywhere, but I guess it
> is supposed to be built at test time.)
> Full ctest log at:
> https://www.aitchison.me.uk/gdal/ctest.391.gnu.errlog
http://www.spatialys.com
