[gdal-dev] GDAL & CAD Files
Kurt Schwehr schwehr at gmail.com
Tue Jun 25 13:03:18 PDT 2024
https://gdal.org/drivers/vector/dwg.html says:
> DWG files are considered to have no georeferencing information through OGR
>From https://gdal.org/programs/ogr2ogr.html, you will need to specify the
spatial reference system / projection with "-s_srs"
-Kurt
On Tue, Jun 25, 2024 at 12:55 PM Ashlyn Powell via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hello GDAL Devs,
> I am new to using GDAL, and I just don't know enough about it yet.  I am
> working with thousands of CAD files (DWG) to extract a project boundary
> line then export it out as a KML. I would love to automate this process.
> Does GDAL have the capability to work with DWG files? Has anyone attempted
> this?    A problem I could see happening is the projection not being set up
> correctly, and all of them exported boundary lines showing up in the ocean.
> Any pointers are much appreciated! I thank you all for your time.
> Thank you,
> Ashlyn Powell
> GIS Analyst | GIS
> ashlyn.powell at blewinc.com <ashlyn.haynes at blewinc.com>
> 888-933-2111 <8889332111>
> www.blewinc.com
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240625/8ec691f0/attachment.htm>
