[gdal-dev] testclosedondestroydm.test
Andrew C Aitchison
andrew at aitchison.me.uk
Tue Jun 25 13:26:42 PDT 2024
On Tue, 25 Jun 2024, Even Rouault via gdal-dev wrote:
> ok, so the exception occurs in the embedded copy of tinyxml inside the ECW
> SDK ?
> You likely need to apply those community patches to your libecwjp2 3.3
> sources:
> https://github.com/rouault/libecwj2-3.3-builds/blob/main/libecwj2-3.3.patch
Thanks. That worked.
Andrew C. Aitchison Kendal, UK
