[gdal-dev] GDAL 3.9.0beta2 available for testing
Even Rouault
even.rouault at spatialys.com
Wed May 1 04:10:42 PDT 2024
The Docker images are now ready. Testing of the Ubuntu-based ones would
be appreciated due to having switched to 24.04 since beta1:
- ghcr.io/osgeo/gdal:ubuntu-full-3.9.0beta2
- ghcr.io/osgeo/gdal:ubuntu-small-3.9.0beta2
- ghcr.io/osgeo/gdal:alpine-normal-3.9.0beta2
- ghcr.io/osgeo/gdal:alpine-small-3.9.0beta2
Even
Le 29/04/2024 à 14:26, Even Rouault via gdal-dev a écrit :
> Hi,
> I've prepared a beta2 of GDAL 3.9.0 as there have been a few
> non-trivial changes since beta1
> The major ones are:
> * pyproject.toml: use numpy>=2.0.0rc1 for python >=3.9 (#9751)
> * Docker: update ubuntu-small and ubuntu-full to 24.04
> * TileDB: migrate away from deprecated APIs, and bump minimum version
> to 2.15
> Other bugfixes:
> * CMake: add missing dependency to generate_gdal_version_h target when
> building {plugin}_core targets
> * CMake: fix generated find_dependency
> * Miramon: various fixes
> * GDALSuggestedWarpOutput2(): make changes of PR #9336 honour
> SRC_METHOD=NO_GEOTRANSFORM. Fixes failure on rasterio
> tests/test_warpedvrt.py::test_transformer_options__width_height
> * Update p-ranav/argparse to latest master; ogrinfo and ogr2ogr:
> update to use store_into(GIntBig&)
> * GDALOpen(): avoid double '.' in error messages related to plugin
> drivers
> * Add OSRIsDerivedProjected() / OGRSpatialReference::IsDerivedProjected()
> * OGR_CT: use PROJJSON internally rather than in WKT:2019 (#9732)
> * GDALArgumentParser: fix dealing with positional arguments that are
> negative numeric values
> * GDALVectorInfo(): fix 3.9.0beta1 regression regarding passing layer
> names
> * Internal libtiff: updated to latest upstream
> * gdalinfo and ogrinfo -json: add newline character at end of JSON
> output (qgis#57266)
> * OGRFeature::SetField(): add warnings when detecting some lossy
> conversions (refs #9792)
> * Arrow/Parquet: fix writing empty point Z with
> GEOMETRY_ENCODING=GEOARROW_INTERLEAVED, and test spatial filtering of
> that encoding (qgis#57228)
> * OGRLayer::WriteArrowBatch(): add tolerance for field type mismatches
> if int32/int64/real; Also add an option IF_FIELD_NOT_PRESERVED=ERROR
> to error out when lossy conversion occurs. (#9792)
> * Parquet: fix ResetReading() implementation, when using the
> ParquetDataset API and when there's a single batch
> * Parquet: fix opening single file Parquet datasets with the
> ParquetDataset API when using PARQUET:filename.parquet
> * OGRCloneArrowArray(): add missing support for 'tss:' Arrow type
> Docker images with 3.9.0beta2 are currently cooking.
> Source snapshots at:
> - https://download.osgeo.org/gdal/3.9.0/gdal-3.9.0beta2.tar.gz
> - https://download.osgeo.org/gdal/3.9.0/gdal-3.9.0beta2.tar.xz
> - https://download.osgeo.org/gdal/3.9.0/gdal390beta2.zip
> Autotest snapshots:
> - https://download.osgeo.org/gdal/3.9.0/gdalautotest-3.9.0beta2.tar.gz
> - https://download.osgeo.org/gdal/3.9.0/gdalautotest-3.9.0beta2.zip
> Even
http://www.spatialys.com
