[gdal-dev] another problem HDF5
Michael Sumner
mdsumner at gmail.com
Wed May 1 13:01:55 PDT 2024
Thanks Even! I've reported it to the providers.
(btw don't gazump me on that book)
Cheers, Mike
On Tue, Apr 30, 2024 at 11:04 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> oh well, so this i actually a HDF5 file using netCDF conventions, but
> likely created with the HDF5 API itself. Per se, this isn't the issue, as
> you've figured it, we can convince the netCDF driver to open it. The lack
> of CRS comes from the fact that the land_mask_map variable has this
> attribute:
> land_mask_map:grid_mapping = "crs: grid_x crs: grid_y" ;
> Which tries to point to the "crs" variable where the CRS is defined. In
> 99% of the products, the value of grid_mapping would be just "crs", and
> life would be good.
> Here they use the "second format" for grid_mapping, described at
> https://cfconventions.org/Data/cf-conventions/cf-conventions-1.11/cf-conventions.html#grid-mappings-and-projections
> "In the second format, it is a blank-separated list of words
> "<gridMappingVariable>: <coordinatesVariable> [<coordinatesVariable> …]
> [<gridMappingVariable>: <coordinatesVariable>…]", which identifies one or
> more grid mapping variables, and with each grid mapping associates one or
> more coordinatesVariables, i.e. coordinate variables or auxiliary
> coordinate variables."
> That documentation isn't 100% crystal clear but the later example 5.10
> "British National Grid" gives an example:
> temp:grid_mapping = "crsOSGB: x y crsWGS84: lat lon" ;
> So you can point to several crs variables, but for each you need to define
> *all* the relevant axis. The way it is done in the product you point
> doesn't match that philosophy (if they wanted to use the second format that
> should rather set "crs: grid_x grid_y", but using the second format here is
> just asking for troubles), and GDAL doesn't manage to parse it.
> You could tune netCDFDataset::SetProjectionFromVar() to recognize this
> weird value for grid_mapping in netCDFDataset::SetProjectionFromVar(),
> around line 3287, but I don't feel myself personally motivated to do that,
> if that product is just an outlier, so I leave it to you as an exercise if
> you wish :-). I guess just testing against the hardcoded "crs: grid_x crs:
> grid_y" value would be good enough to handle that outlier.
> (Someone, super bored, should author a book about with horror stories with
> netCDF and HDF georeferencing. There's a lot of material. Although likely
> not to be a best seller)
> Even
> Le 30/04/2024 à 09:45, Michael Sumner via gdal-dev a écrit :
> This time, with:
> https://n5eil01u.ecs.nsidc.org/ATLAS/ATL20.004/2018.10.14/ATL20-01_20181001010615_00370101_004_01.h5
> NETCDF gets the geotransform (from x_grid,y_grid which report in the
> metadata) but no crs:
> gdalinfo NETCDF:ATL20-02_20181001010615_00370101_004_01.h5 -sd 1 -nomd
> Driver: netCDF/Network Common Data Format
> Files: ATL20-02_20181001010615_00370101_004_01.h5
> Size is 316, 332
> Origin = (-3950000.000000000000000,4350000.000000000000000)
> Pixel Size = (25000.000000000000000,-25000.000000000000000)
> Corner Coordinates:
> Upper Left (-3950000.000, 4350000.000)
> Lower Left (-3950000.000,-3950000.000)
> Upper Right ( 3950000.000, 4350000.000)
> Lower Right ( 3950000.000,-3950000.000)
> Center ( 0.000, 200000.000)
> Band 1 Block=500x500 Type=Float64, ColorInterp=Undefined
> Unit Type: degrees_north
> HDF5 doesn't get geotransform or crs:
> gdalinfo ATL20-02_20181001010615_00370101_004_01.h5 -sd 1 -nomd
> Driver: HDF5Image/HDF5 Dataset
> Size is 316, 332
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 332.0)
> Upper Right ( 316.0, 0.0)
> Lower Right ( 316.0, 332.0)
> Center ( 158.0, 166.0)
> Band 1 Block=500x500 Type=Float32, ColorInterp=Undefined
> NoData Value=3.4028235e+38
> This is unproblematically NSIDC 25km south, there's no mix of poles in
> this one. I honestly don't know what to expect from these files generally
> though I get my hopes up sometimes haha.
> I'll have to keep notes and explore more deeply with native HDF5 tools.
> Cheers, Mike
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
Michael Sumner
Hobart, Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240502/125edc87/attachment.htm>
