[gdal-dev] Re-post, user-defined
Liyuneh Gebre liyenew at gmail.com
Fri May 3 06:29:44 PDT 2024
Dear Even,
 Apologies for taking your time. I couldn’t locate the mentioned error in
arcpy. It runs smoothly . I’ve shared  the arcpy projection python script
and associated data with the link
https://u.pcloud.link/publink/show?code=kZj5wh0ZtFWXtI9UGjQiD6KXxn5A9hiWDpEX.
If you find a way using gdaltransform and gdalwarp to achieve the
re-projection, that would be appreciated.
thank you in advance
On Tue, Apr 30, 2024 at 2:55 AM Liyuneh Gebre <liyenew at gmail.com> wrote:
> Well the arcpy made transformation before re-projection. Appended the
> sample script in the shared folder as txt. Anyway how can I achieve this
> ArcPy output re-projection from gdal with the given gdalinfo on the input
> file  and by editing the PROJ.4 string (target projection )?
> PARAMETER["Latitude of natural origin",20,
> ANGLEUNIT["degree",0.0174532925199433],
> ID["EPSG",8801]],
> PARAMETER["Longitude of natural origin",6378137,
> ID["EPSG",8802]],
> PARAMETER["False easting",5,
> LENGTHUNIT["metre",1],
> ID["EPSG",8806]],
> On Tue, Apr 30, 2024 at 1:11 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> At first sight, I'd say that the ArcPy output is incorrect. The SRS
>> definition of its output doesn't match what you want since it has
>> ID["EPSG",8801]],
>> ID["EPSG",8802]],
>> ID["EPSG",8806]],
>> The "Longitude of natural origin" is completely wrong, and should be 5
>> given the PROJ.4 string you mentionned
>> And the the "False easting" should be 0.
>> The output of GDAL looks plausible.
>> Le 30/04/2024 à 00:00, Liyuneh Gebre a écrit :
>> Hi Even,
>> thank you for your response,
>> gdal version is: GDAL 3.6.4, released 2023/04/17
>> I got the defined target projection included in the link. yes, it's
>> geocentric and for further exploration the custom project transformation
>> file .gtf extension is also included.
>> On Mon, Apr 29, 2024 at 4:23 PM Even Rouault <even.rouault at spatialys.com>
>> wrote:
>>> Hi,
>>> it is difficult to help you with just the elements you've provided.
>>> What could be helpful is:
>>> - the output of gdalinfo on the input file
>>> - the output of gdalinfo on the output file generate by ArcPy
>>> - how you define the target projection in ArcPy
>>> - the output of gdalinfo on the output file generate by GDAL
>>> - links to all the above files
>>> - the GDAL version you use
>>> Totally blind guess: try to add "+towgs84=0,0,0 " in your -t_srs PROJ
>>> string, to ask PROJ to consider that your target CRS datum has the same
>>> center and axis orientation as WGS84 (and thus go to geographic <-->
>>> geocentric conversion when changing datums). Otherwise without datum
>>> shifts, PROJ will consider that longitude,latitude coordinates of the
>>> geographic CRS underlying the source and target CRS is the same.
>>> Even
>>> Le 29/04/2024 à 14:57, Liyuneh Gebre via gdal-dev a écrit :
>>> Dear all,
>>> I am requesting again if you kind have some responds or direction, thank
>>> you
>>> I have difficulties in accurately reprojecting a raster file to a
>>> user-defined projection.
>>> I used the following commands in gdal while the output is not similar to
>>> arcpy results.  kindly offer your guidance to achieve the same result.  The
>>> arcpy uses custom transformation and then reprojection.
>>> gdalwarp -t_srs '+proj=laea +a=6378137.0 +f=0.0 +pm=0 +x_0=0.0 +y_0=0.0
>>> +lon_0=20.0 +lat_0=5.0 +units=m +axis=enu +no_defs'  -dstalpha  -wo
>>> SOURCE_EXTRA=1000 -r nearest rain_in.bil rain_projected.bil
>>> *Liyuneh Gebre**, **Associate Researcher*
>>> *Ethiopian Institute of Agricultural Research,EIAR *
>>> *Cell Phone:+251 911858155 *
>>> *linkedIn: https://www.linkedin.com/in/liyuneh-gebre-b842b440/
>>> <https://www.linkedin.com/in/liyuneh-gebre-b842b440/> *
>>> *skype:liyenew_1*
>>> *Addis Ababa, Ethioipa*
>>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> -- http://www.spatialys.com
>>> My software is free, but my time generally not.
>> *skype:liyenew_1*
> *Ethiopian Institute of Agricultural Research,EIAR*
> *Cell Phone:+251 911858155*
> <https://www.linkedin.com/in/liyuneh-gebre-b842b440/>*
> *skype:liyenew_1*
*skype:liyenew_1*
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240503/3444a6ca/attachment.htm>
