[gdal-dev] FileGDB that does not open
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Wed May 8 07:49:42 PDT 2024
FileGDB data from https://vgin.maps.arcgis.com/home/item.html?id=29627d7c051a47dc8ce71b4484531ab3 "Virginia_Parcel_Dataset_2024Q1.gdb" does not open with GDAL 3.9.0dev. The error is:
Warning 1: VA_Parcels layer has a Virginia_Parcel_Dataset_2024Q1.gdb\a00000009.gdbtable.cdf file whose format is unhandled
I do not need the data. I am only testing, but maybe someone wants to study what is special in the a00000009.gdbtable.cdf file.
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240508/29ba00f7/attachment-0001.htm>
