[gdal-dev] FileGDB that does not open
Holger Jaekel
holger.jaekel at gmx.de
Thu May 9 01:21:21 PDT 2024
Jukka
Am 08.05.24 um 16:49 schrieb Rahkonen Jukka via gdal-dev:
> Warning 1: VA_Parcels layer has a
> Virginia_Parcel_Dataset_2024Q1.gdb\a00000009.gdbtable.cdf file whose
> format is unhandled
This is not new in 3.9.0dev, I get the same warning with 3.8.5. CDF
files are not supported by the OpenFileGDB driver. You need the ESRI
FileGDB API to read those files.
From the documentation of OpenFileGDB:
Drawbacks of the OpenFileGDB driver:
• Cannot read data from compressed data in CDF format (Compressed Data
Format).
Holger
