[gdal-dev] Max Zoom level restriction
Raghav Singh raghav.singh at eagleview.com
Wed May 8 07:53:44 PDT 2024
In my application I am making request to mapserver and sending this file gdal driver file -
 <GDAL_WMS>
    <Service name="TMS">
        <ServerUrl>http://gserve-connect/v1/map/urn:v4:spatial-data:raster:visual:gWILJv1HzBdKA:0/tile?tileRow=${y}&tileColumn=${x}&zoomLevel=${z}&minZoom=6&maxZoom=20</ServerUrl>
    </Service>
    <DataWindow>
        <UpperLeftX>-20037508.34</UpperLeftX>
        <UpperLeftY>20037508.34</UpperLeftY>
        <LowerRightX>20037508.34</LowerRightX>
        <LowerRightY>-20037508.34</LowerRightY>
        <TileLevel>21</TileLevel>
        <TileCountX>1</TileCountX>
        <TileCountY>1</TileCountY>
        <YOrigin>bottom</YOrigin>
    </DataWindow>
    <Projection>EPSG:3857</Projection>
    <BlockSizeX>256</BlockSizeX>
    <BlockSizeY>256</BlockSizeY>
    <BandsCount>3</BandsCount>
    <Timeout>60</Timeout>
    <MaxConnections>4</MaxConnections>
    <ZeroBlockHttpCodes>204,404,500</ZeroBlockHttpCodes>
    <ZeroBlockOnServerException>true</ZeroBlockOnServerException>
</GDAL_WMS>
so for some request zoom Level is going beyond max Zoom this is the request - https://svc.pict.com/Image/2FD6BE87-8168-73F9-63DD-0BFD5FE63EDD/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=44.73635069554558896,-63.61617776442430028,44.73674930445441333,-63.61582223557569904&CRS=EPSG:4326&WIDTH=751&HEIGHT=843&LAYERS=PICT-NSPVSC22-OUKuEawvk2&STYLES=&FORMAT=image/png&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96&TRANSPARENT=TRUE so how could I know from this request what is the zoom level requested because when I run mapserver then only i see what zoom level request are going or do i have put a restriction in mapserver only or i have to set the tileLevel here to 20 so that it takes to that zoom level only.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240508/7f94ec2a/attachment.htm>
