[gdal-dev] GPKG to PG single transaction, different schemas
Matteo Ghetta
matteo.ghetta at gmail.com
Tue May 14 08:30:43 PDT 2024
Hi all,
I've a geopackage with many layers (in the following example let's
pretend just 2) that I want to import in a single transaction
(important!) into a PG database.
GPKG and PG table names are the same, but it can happen that the tables
are in different schemas. I couldn't find the correct flags combination
to specify the destination schema.table_name.
With the following command features of first_table are appended to the
second_table table:
ogr2ogr --debug ON -f PostgreSQL "PG:host=localhost user=matteo
password=my_pws dbname=test" -append /home/matteo/export_db.gpkg
first_schema.first_layer second_schema.second_layer
same with the -nln option:
first_layer -nln first_schema.first_layer second_layer -nln
Should I specify a vrt catalog or am I missing some options?
Cheers and thanks!
Matteo
