[gdal-dev] Discrepancy in reported Spatial Reference b/n gdalinfo and arcpy
Even Rouault even.rouault at spatialys.com
Tue May 14 09:16:48 PDT 2024
Le 14/05/2024 à 18:08, Liyuneh Gebre a écrit :
> hi,
> thanks for your kind commitment.  I tried the docker version and
> unfortunately it shows the same result.
That's expected. The fix has been done post 3.9.0. This will be
available in 3.9.1
> On Sun, May 12, 2024 at 4:02 PM Even Rouault
> <even.rouault at spatialys.com> wrote:
>     Hi,
>     fix in https://github.com/OSGeo/gdal/pull/9909
>     Le 12/05/2024 à 12:06, Javier Jimenez Shaw via gdal-dev a écrit :
>>     I do not know if there is any documentation from esri about that
>>     specific format for LAMBERT_AZIMUTHAL. It would be great.
>>     And also I am surprised that in 13 years nobody complained.
>     Digging a bit in the web, I found some. See code comments in the
>     pull request:
>     https://github.com/OSGeo/gdal/pull/9909/files#diff-ed43401b4bc3e43302f36a0502b4106a7fa0866cd5e3c6ac4ccb3823d10f3085R436
>     Even
>     http://www.spatialys.com
>     My software is free, but my time generally not.
> /*Liyuneh Gebre*//, ////Associate Researcher///
> /Ethiopian Institute of Agricultural Research,EIAR
> /Cell Phone:+251 911858155
> /linkedIn: https://www.linkedin.com/in/liyuneh-gebre-b842b440/
> //skype:liyenew_1//
> /Addis Ababa, Ethioipa/
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240514/64689e37/attachment.htm>
