[gdal-dev] GDAL WMTS get tiles no documentation
Michał Kowalczuk michkowalczuk at gmail.com
Wed May 29 01:14:14 PDT 2024
Because this is not clear in documentation, especially in WMTS driver docs,
my question is strictly about this issue to programmers who have already
explored this topic.
Regards
Michal
W dniu śr., 29.05.2024 o 10:04 Rahkonen Jukka <
jukka.rahkonen at maanmittauslaitos.fi> napisał(a):
> Hi,
> No, I am not sure because I do not program myself. Reading this document
> https://gdal.org/user/multithreading.html makes me feel that it is
> possible to do some things in parallel, but the programmer must know how to
> do it right.
> -Jukka Rahkonen-
> *Lähettäjä:* Javier Jimenez Shaw <j1 at jimenezshaw.com>
> *Lähetetty:* keskiviikko 29. toukokuuta 2024 10.41
> *Vastaanottaja:* Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
> *Kopio:* Michał Kowalczuk <michkowalczuk at gmail.com>;
> gdal-dev at lists.osgeo.org
> *Aihe:* Re: [gdal-dev] GDAL WMTS get tiles no documentation
> On Wed, 29 May 2024 at 08:59, Rahkonen Jukka via gdal-dev <
> gdal-dev at lists.osgeo.org> wrote:
> Hi,
> When you have a RasterBand  from the WMTS data source, it is abstracted
> and you can read the raster data just like from any other data source and
> raster band
> https://gdal.org/tutorials/raster_api_tut.html#reading-raster-data “There
> are a few ways to read raster data, but the most common is via the
> GDALRasterBand::RasterIO() method. This method will automatically take care
> of data type conversion, up/down sampling and windowing.” GDAL knows which
> tiles to read.
> I do not know if the WMTS driver can do parallel tile downloads. If not,
> it is possible to run many RasterIO() at the same time, each reading data
> from a different window like in this rasterio document
> https://rasterio.readthedocs.io/en/latest/topics/concurrency.html.
> Jukka, are you sure you can run several RasterIO in parallel (on the same
> dataset)? in GDAL GeoTIFF you cannot: the cache may be corrupted. In that
> case I open several datasets over the same file. I do not know about WMTS.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Michal
> Kowalczuk via gdal-dev
> *Lähetetty:* keskiviikko 29. toukokuuta 2024 9.08
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] GDAL WMTS get tiles no documentation
> Hi GDAL fellows
> This is my first post on this mailing list, so I'm asking for
> understanding.
> As all we know the purpose of using WMTS over WMS, I'd like to implement
> parallel downloading tiles from service using C API.
> In my opinion GDAL documentation (
> https://gdal.org/drivers/raster/wmts.html) says nothing on this topic.
> I can get capabilities from WMTS, I can open the selected subdataset but
> how to get tiles for given extent? I could not find any information how to
> do it, even in the GDAL tests on github.
> I am kindly asking for tips. It also can be in python. How using pure GDAL
> API fetch tiles to dynamically complete the displayed map. This is my goal.
> Thank you!
> Michal
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240529/9a97fc54/attachment-0001.htm>
