[gdal-dev] GDAL WMTS get tiles no documentation
Even Rouault even.rouault at spatialys.com
Wed May 29 03:41:32 PDT 2024
The WMS cache (which is used underneath by the WMTS driver) writes each
tiles in a separate file. So if you use multi-threaded, as long as you
read in parallel different GDALDataset* object on the WMTS filename, and
read disjoint areas, that should be fine. There might be a slight risk
of things going bad if you happened to read the same tile from different
GDALDataset* object at the same time, as it could potentially read a
partially written cached tile, or concurrently write the tile in the
cache and corrupt it. The logic is in frmts/wms/gdalwmscache.cpp
Even
Le 29/05/2024 à 10:14, Michał Kowalczuk via gdal-dev a écrit :
> Because this is not clear in documentation, especially in WMTS driver
> docs, my question is strictly about this issue to programmers who have
> already explored this topic.
> Regards
> Michal
> W dniu śr., 29.05.2024 o 10:04 Rahkonen Jukka
> <jukka.rahkonen at maanmittauslaitos.fi> napisał(a):
>     Hi,
>     No, I am not sure because I do not program myself. Reading this
>     document https://gdal.org/user/multithreading.html makes me feel
>     that it is possible to do some things in parallel, but the
>     programmer must know how to do it right.
>     -Jukka Rahkonen-
>     *Lähettäjä:*Javier Jimenez Shaw <j1 at jimenezshaw.com>
>     *Lähetetty:* keskiviikko 29. toukokuuta 2024 10.41
>     *Vastaanottaja:* Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
>     *Kopio:* Michał Kowalczuk <michkowalczuk at gmail.com>;
>     gdal-dev at lists.osgeo.org
>     *Aihe:* Re: [gdal-dev] GDAL WMTS get tiles no documentation
>     On Wed, 29 May 2024 at 08:59, Rahkonen Jukka via gdal-dev
>     <gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>> wrote:
>         Hi,
>         When you have a RasterBand  from the WMTS data source, it is
>         abstracted and you can read the raster data just like from any
>         other data source and raster band
>         https://gdal.org/tutorials/raster_api_tut.html#reading-raster-data
>         <https://gdal.org/tutorials/raster_api_tut.html#reading-raster-data>“There
>         are a few ways to read raster data, but the most common is via
>         the GDALRasterBand::RasterIO() method. This method will
>         automatically take care of data type conversion, up/down
>         sampling and windowing.” GDAL knows which tiles to read.
>         I do not know if the WMTS driver can do parallel tile
>         downloads. If not, it is possible to run many RasterIO() at
>         the same time, each reading data from a different window like
>         in this rasterio document
>         https://rasterio.readthedocs.io/en/latest/topics/concurrency.html
>         <https://rasterio.readthedocs.io/en/latest/topics/concurrency.html>.
>     Jukka, are you sure you can run several RasterIO in parallel (on
>     the same dataset)? in GDAL GeoTIFF you cannot: the cache may be
>     corrupted. In that case I open several datasets over the same
>     file. I do not know about WMTS.
>         -Jukka Rahkonen-
>         *Lähettäjä:*gdal-dev <gdal-dev-bounces at lists.osgeo.org
>         <mailto:gdal-dev-bounces at lists.osgeo.org>> *Puolesta *Michal
>         *Lähetetty:* keskiviikko 29. toukokuuta 2024 9.08
>         *Vastaanottaja:* gdal-dev at lists.osgeo.org
>         *Aihe:* [gdal-dev] GDAL WMTS get tiles no documentation
>         Hi GDAL fellows
>         This is my first post on this mailing list, so I'm asking for
>         understanding.
>         As all we know the purpose of using WMTS over WMS, I'd like to
>         implement parallel downloading tiles from service using C API.
>         In my opinion GDAL documentation
>         (https://gdal.org/drivers/raster/wmts.html
>         <https://gdal.org/drivers/raster/wmts.html>) says nothing on
>         this topic.
>         I can get capabilities from WMTS, I can open the selected
>         subdataset but how to get tiles for given extent? I could not
>         find any information how to do it, even in the GDAL tests on
>         github.
>         I am kindly asking for tips. It also can be in python. How
>         using pure GDAL API fetch tiles to dynamically complete the
>         displayed map. This is my goal.
>         Thank you!
>         Michal
>         _______________________________________________
>         gdal-dev mailing list
>         https://lists.osgeo.org/mailman/listinfo/gdal-dev
>         <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240529/0403cc46/attachment.htm>
