[gdal-dev] RFC 96 adjustment: Re: Call for review and discussion on RFC96: Deferred in-tree C++ plugin loading
Even Rouault
even.rouault at spatialys.com
Wed May 29 13:57:09 PDT 2024
I just wanted to point that a shortcoming of RFC 96
(https://gdal.org/development/rfc/rfc96_deferred_plugin_loading.html)
was discovered. https://github.com/OSGeo/gdal/pull/10068 will address
it. Please refer to it for the details.
This PR is aimed at being backported for 3.9.1. Pedantically this will
be an ABI change (between in-tree drivers built as plugins and core),
although I suspect that it shouldn't be noticed for most
use&distribution scenarios. Not clear if that's worth a SONAME bump for
3.9.1, or if that would be more an annoyance.
Even
Le 02/11/2023 à 12:59, Even Rouault via gdal-dev a écrit :
> Hi,
> I'm seeking for feedback and review on a new RFC (RFC 96: Deferred
> in-tree C++ plugin loading),
> detailed in https://github.com/OSGeo/gdal/pull/8648, whose summary is:
> This RFC adds a mechanism to defer the loading of in-tree C++ plugin
> drivers to
> the point where their executable code is actually needed, and converts
> a number
> of relevant drivers to use that mechanism. The aim is to allow for
> more modular
> GDAL builds, while improving the performance of plugin loading.
> (This is material only for GDAL 3.9 of course)
> Even
http://www.spatialys.com
