[gdal-dev] clear band level metadata
Michael Sumner mdsumner at gmail.com
Wed May 29 23:12:37 PDT 2024
Hello, I have this process to convert a URL to a MEM dataset.
It's not the target data but it's representative, a netcdf with band-level
and dataset-level metadata. We can clear the dataset level with
COPY_SRC_MDD, but I can't see how to do that for the band level. We're
hoping to keep this  without generating files, the final step uses VSI to
read into a byte array.
Can I clear the band metadata without an intermediate dataset? Opening in
update mode breaks the COG layout (or is that ok to do this with
IGNORE_COG_LAYOUT_BREAK=YES ?).
from osgeo import gdal
gdal.UseExceptions()
dsn = "vrt:///vsicurl/
https://www.ncei.noaa.gov/data/sea-surface-temperature-optimum-interpolation/v2.1/access/avhrr/202405/oisst-avhrr-v02r01.20240511.nc?sd_name=sst
opts = gdal.TranslateOptions(format = "COG",
     creationOptions = [ "COMPRESS=ZSTD", "PREDICTOR=STANDARD",
"RESAMPLING=AVERAGE",
     "SPARSE_OK=YES", "COPY_SRC_MDD=NO"])
ds = gdal.Open(dsn)
tmp = "/vsimem/tmp1.tif"
## here we lose the dataset-level metadata as desired with COPY_SRC_MDD
gdal.Translate(tmp, ds, options = opts)
## but the band metadata is still there
lds = gdal.Open(tmp)
#{'add_offset': '0', 'long_name': 'Daily sea surface temperature',
'NETCDF_DIM_time': '16932', 'NETCDF_DIM_zlev': '0', 'NETCDF_VARNAME':
'sst', 'scale_factor': '0.0099999998', 'units': 'Celsius', 'valid_max':
'4500', 'valid_min': '-300', '_FillValue': '-999'}
lds.Close()
ds.Close()
I guess I need to open and translate to another COG dataset after breaking
the COG layout?
## now open in rw, to zap band level md (but breaks COG layout)
#lds = gdal.OpenEx(tmp, gdal.GA_Update, open_options =
 ["IGNORE_COG_LAYOUT_BREAK=YES"])
#lds.GetRasterBand(1).SetMetadata({})
#lds.Close()
#Warning 1: tmp1.tif: The IFD has been rewritten at the end of the file,
which breaks COG layout.
ds = gdal.Open(tmp)
#Warning 1: tmp1.tif: This file used to have optimizations in its layout,
but those have been, at least partly, invalidated by later changes
Cheers, Mike
Michael Sumner
Research Software Engineer
Australian Antarctic Division
Hobart, Australia
e-mail: mdsumner at gmail.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240530/37e21f19/attachment.htm>
