[gdal-dev] OGR SQL CAST geometry example
Dan Jacobson jidanni at jidanni.org
Thu May 30 17:49:31 PDT 2024
$ ogrinfo 0.lines.kml -q -dialect SQLITE -sql \
'SELECT ST_PointN(GEOMETRY, generate_series(1, ST_NPoints(GEOMETRY))) FROM "0"'
ERROR 1: In ExecuteSQL(): sqlite3_prepare_v2(....
  no such function: generate_series
