[gdal-dev] OGR SQL CAST geometry example
Even Rouault even.rouault at spatialys.com
Thu May 30 18:06:14 PDT 2024
According to http://www3.sqlite.org/series.html, generate_series() is
only built in the sqlite3 command line utility, not in the library
itself. That said, with some work, the source at
https://www.sqlite.org/src/file/ext/misc/series.c could potentially be
embedded into libgdal
Le 31/05/2024 à 02:49, Dan Jacobson a écrit :
> $ ogrinfo 0.lines.kml -q -dialect SQLITE -sql \
> 'SELECT ST_PointN(GEOMETRY, generate_series(1, ST_NPoints(GEOMETRY))) FROM "0"'
> ERROR 1: In ExecuteSQL(): sqlite3_prepare_v2(....
>    no such function: generate_series
http://www.spatialys.com
