[gdal-dev] OGR SQL CAST geometry example
Daniel Baston
dbaston at gmail.com
Thu May 30 18:30:51 PDT 2024
If a single MULTIPOINT record is OK, then you can do
ogrinfo test.shp -q -dialect SQLITE -sql 'SELECT
ST_DissolvePoints(GEOMETRY) FROM test'
Dan
On Thu, May 30, 2024 at 8:49 PM Dan Jacobson via gdal-dev
<gdal-dev at lists.osgeo.org> wrote:
> $ ogrinfo 0.lines.kml -q -dialect SQLITE -sql \
> 'SELECT ST_PointN(GEOMETRY, generate_series(1, ST_NPoints(GEOMETRY))) FROM "0"'
> ERROR 1: In ExecuteSQL(): sqlite3_prepare_v2(....
> no such function: generate_series
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
